77 vector recore
Re: 77 vector recore
ok so i worked on the boat tonite i got it in my shop so i can work on it in all weather i got all the core out an the stringers now just got the easiest part to do the bow mite just make it open bow lol jj
ok chet i do got two boxes on the side of my motor look ing at the front there on the right side i didnt see a box on the left side but could have over looked it do i just take the boxes and all the wiring off all the way to were the wires go or do i have to rewire something and how do i retime the thing ive never done that either so...and i dont think its got the rev box it will turn close to 7500 and heres some pics of the motor and core
right side of the motor
leftside of motor
leftside of motor
Looks like you're going at a good pace!
Make sure you grind the bottom before you start installing the new core. You will end up with a nice creme color under the dark glass.
If you're turning past 6200 your limiter has been removed. The box with the blue, white and a green wire on the side is your oil injection modual. The one on the top is your timing advance modual it effects timing at idle but can fail and cause problems up higher so it's better just to remove it.
As far as timing you will be way better off picking up a factory manual. I could explain it but the manual will help out later as well.
ok iam going to get one and is the timing adavanced or retard that you said to do 25* and just remove all the wires on both boxes i really do appreciate the help from you guys as iam still getting my feet wet with all this outboard and core stuff
yea i have been just working on it a couple hours aday for like 4 days now but its coming along bout got the hard part done i believe just ready to get it going back to gether so when i can look back and say i did that so thanks again guys to bad yall are to far away for a weekend ride together
Your moving right along. Looking great so far.
thanks hippie i really like when i get comments on my progress it help me keep motivated on the project thanks again
steven
steven
ok so i just ordered all my stuff for my boat and going now to get my plywood for my stringers and transom were getting close to getting something coming back together its going to be wonder full with have a study boat i can trust for my speeds will repost soon when i get my transom started and clued together and stringers built
First off, I like your energy. Your really on it. Were your stringers in top of the core or adhered to the hull and core around it. I cant tell in the pics. As for the core up in the bow, you'll have a seam down the center in the V. Bevel the edges where they meet. for the transom, laminate 3 1/2" real marine ply together and let cure. Cut to size and adhere to the outer hull kinda like the core and clamp it and let it cure then laminate over it. I was lucky, mine wasn't rotten. As far as the mounting holes I used a 3M product, not 5200 because you'll never get it apart. I think it was 8200 or something like that. Make sure all your surfaces are clean before any laminating. Use acetone for final cleaning. I'll be around if you have any ??? Keep up the good work.
Rick.
Rick.
hey rick thanks for the advice i got to get me some big a clamps i got a bunch of wood clamps and i got my transom built to day and its ready to go i put in place nic and snug in there had to lightly tap it in with a hammer so looking good there
and my stringers were in the hull and cored around them iam going back the same way and iam going to make them tie in to my transom like some other people did on here yea i got all my stuff ordered today should be getting out to me tommorw should have it in about a week i got it from mertons in ma....iam grinding everything now to get it ready them iam going to start on the bow after everything else is done an ready going to make my stringers tomm will post some pics of them and the transom thanks again every one for the support and help
steven
steven
well stoped working on it around 8 tonite i got all the core grinded down and the transom didnt have time to post any pictures gang sorry will do so tomm now just got to get under the bow and make some stringers and then will be ready for the new core to go in and the stringers yee haw should be a blast once done iam so ready for it too be cant wait
steven
steven
- 5302 Views
Nov 01, 2009 9:26 am
- 4561 Views
Nov 01, 2009 12:28 pm
- 5295 Views
Nov 29, 2009 4:41 pm
- 12722 Views
- Last post by turboregal63split
Jul 12, 2010 1:06 pm
- 15Replies
- 10176 Views
Nov 20, 2009 5:03 pm
