restoring a Ventura II
Re: restoring a Ventura II
Its short strand fiberglass reinforced bondo filler. The can stated it was water proof.
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
'87 200 evinrude xp
'79 baja 180ss
Keep in mind that im not a professional boat builder. I have managed to get some rigging done even with all the setbacks. Feels like 1 step forward and 2 steps back every time I touch it. Well, I have the gauges mounted and mostly wired, switch panel mounted and wired, bow and stern lights mounted, transom tie down eyes in and motor/jackplate mounted. We (quarterhorse and I) took our time mounting the jackplate to make sure its centered and level with the pad. This took longer than expected, but I feel we did it the right way. I have found it very difficult to drill into fresh gel that I have spent so much time working with. Overall, Im pretty happy with the hull.
Once I got the motor mounted to the jackplate and started to let it down the front of the trailer started to come up. Fudge! I moved the boat forward on the trailerand that created a problem with the nosecone hitting the center roller. I threw a sandbag on the front for now as it was getting late. I crawled under the trailer and found out the axle, fenders and steps are on a sub assembly thats bolted to the trailer frame. Sweet! Tomorrow I will move the axle back and get this balanced out.
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
'87 200 evinrude xp
'79 baja 180ss
Here is todays progress... Had to make a cut to make room for the fuel tank. Looks like a giant space, but its really not. Then, I cut, fit and glued the carpet in. F the carpet work. I'm not a carpenter. Here's pics...
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
'87 200 evinrude xp
'79 baja 180ss
Your Ventura looks awesome, you did an excellent job on the whole thing
Actually, i'm not. My left hand is to stupid to run a smart phone to take the pic so it got the honors.
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
'87 200 evinrude xp
'79 baja 180ss
Got it on the picture taking - Boat looks great. We've been slowly chipping away at the core on the Ventura II, but out main focus is finishing the splash well delete / transom replace on the Vulture. Now comes the rewarding part for you. Getting everything back in the boat and doing it exactly like you want it, custom to your needs. The dash looks great. Keep posting the progress! Bill
Thanks. The nice comments keep my motivation going. I'm working on fitting the trailer to the hull right now. It was under a bass hull. So far i've move the axle back 18" and have about 100lbs of tongue weight. This is without the steering, fuel tank and battery installed. Im thinking it needs to go back another two inches to be safe.
I want a gps speedo but didn't want to pay for it at the time. They are spendy! I will just use a handheld when i want to know the speed. None of the water i boat in has limits anyway.
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
'87 200 evinrude xp
'79 baja 180ss
- 4254 Views
- Last post by Fast Viper
Jan 31, 2013 10:11 am
- 5111 Views
Jan 28, 2013 12:10 am
- 5048 Views
- Last post by LSaupe
Jan 29, 2013 7:55 pm
- 17737 Views
- Last post by silkeysak
Mar 21, 2013 9:34 pm
- 4201 Views
Feb 10, 2013 6:00 pm
