Page 1 of 1
87 Vegas Core Questions
Posted: May 09, 2011 5:38 pm
by ACK880
I have a couple questions about the core of my Vegas. I have discovered that the back 4' of the v portion of my hull's core is pretty bad. It basically starts where the hull steps. I have that already cleaned out and ready to recore. My question is regarding the pad. I have not taken any samples, it appears to be very solid and I didn't want to have to tear out more than needed. Is the pad also balsa cored? And if so how thick? I have done work in checkmates but this is my first hydro.
Re: 87 Vegas Core Questions
Posted: May 09, 2011 5:53 pm
by 77viper
The pad is cored with 1/2" bulsa. Is it a v or xt bottom?
Posted: May 09, 2011 5:57 pm
by ACK880
Thanks I'll be sure to check it out...
It's an XT hull.
Posted: May 09, 2011 6:01 pm
by ACK880
It's an XT hull.
Posted: May 09, 2011 6:11 pm
by VultureNo2
Hate to be the guy with the bad news but assume it's bad and get it out. I don't know the years, Chet can better explain but the XT's were known to be bad. If you have rot in back you probably have more rot. If so don't be afraid to do it right. The piece of mind of knowing outweighs the time and cost. If you love the boat, you will like it more when it's lighter weight. Love to see what it looks like. Post some pictures of both the outside and anywhere the floor is up. After doing a core. you can tell pretty much from a photo where the dark spots are. Bill
Posted: May 09, 2011 10:07 pm
by 77viper
Bill is correct about the piece of mind knowing all the core is good and dry.
I'm not so sure about the tx's but have heard the build quality wasn't the best on the yt's from 87-89.
