Dual Trim/Tilt and Jack Plate switch on steering wheel
I have a turning signal style setup that has jack plate control and trim/tilt control on the steering wheel. When I put it all back together, everything performed perfectly but the switches are both bad. I poked around a little with no luck at local marina's for the replacements without any luck. Anyone know where I can find replacements for it or another on wheel setup. Please put a link up if you have a good source. Thanks, Bill
Re: Dual Trim/Tilt and Jack Plate switch on steering wheel
Thanks Russ, Something like that but I don't have hydraulic steering. Do you think it matters? Bill
- Has thanked: 353 times
Here is all that I have on mine and for now its gonna have to do. LoL
Just a simple up and down. I cant imagine it would cost a whole lot either.
Man, I forgot what my boat used to look like. LoL
Yeah - my searching left me with a few options both short term and long term. Hippie, does that setup handle both tilt/trim and jack plate or would I need 2 of them? I think I am about a week away from a first water test. It depends how much I get done tomorrow. Bill
You will need 2 of them.
yes, You would need 2 of them. That one just does the trim. I have manual jack plate so I only need the 1.
http://www.bobsmachine.com/products/pro-trim-switch.cfm look at these at Bobs Machine Shop
Good info guys got the Voyager out yesterday time to set it up it def needs trim on the wheel and a hot ft as she is a handfull .
Yeah Russ - That's what I am looking for. I took the switches off the bracket and was just trying to replace the switches, but have spent too much time on it already. I found one switch so far that will work, not a perfect fit, but want a better long term solution. Thanks. Bill
- 4011 Views
- Last post by St.Croix_Rat
Jul 10, 2012 11:01 am
- 4929 Views
Aug 18, 2012 8:03 pm
- 4017 Views
- Last post by transomstand
Jul 11, 2012 11:17 am
- 3411 Views
Jul 11, 2012 11:57 pm
- 7786 Views
- Last post by jacklake2003
Jul 17, 2012 9:32 am
