I see this quite often and thought I should share it in hopes of saving some headaches or a powerhead. If you are running Mercury gray fuel line and it's 2 years old or older replace it with ethanol safe line. The old fuel line has red writing on it and the new stuff has blue writing. What happens to the old line is the inner liner comes apart and will cause a fuel restriction and will cause a lean condition and we all know where that can lead. The bad part is it looks fine from the outside but inside it looks like this
I know they are crappy cell pictures but you get the point. I had a guy drive from Canada "about 10 hours" because of this.
check your fuel line
Re: check your fuel line
Good Advice! I've added a clear in-line fuel filter so I'm able to "see" any problems. It came in handy this past spring when I noticed phase-seperation in my E-10 fuel left over from the fall.
good info chet. ive always been a 3/8 black rubber line from the parts house kind of guy, but i think we have that grey on our g-3 ill have to check that out
- 6730 Views
- Last post by Rut311969
Sep 24, 2012 10:40 pm
- 9232 Views
- Last post by varmint1
Sep 26, 2012 8:06 pm
- 23925 Views
- Last post by seahorsemax
Mar 11, 2017 4:44 pm
Chevy 350 Fuel Injectors, Computer Chip, mufflers and gears.
Last post by valero4me « Sep 27, 2012 4:57 am - 1Replies
- 8438 Views
- Last post by valero4me
- 4610 Views
Oct 01, 2012 10:02 am
