HELP!! What am i looking at??
i took the carpet out and found a poorly cut piece of plywood and removed it to find all this underneath....what am i even looking at? I need help knowing what im dealing with here.
- T2012-04-03_21-23-29_311-1.jpg (196.69 KiB) Viewed 5224 times
Re: HELP!! What am i looking at??
- H2012-04-03_21-23-40_139-1.jpg (224.76 KiB) Viewed 5223 times
Looks to me like some really bad rotted core, but it's hard to tell from the picture. Is there another layer of glass, then rot, then the hull? If it is rotted core, you will be glad it is that bad. It sucks if it is half good. Hard to remove. If you can, do the bow and rear before the middle first. JMO. Bill
Your looking at a lot of grinding and Fiberglas work. Really that's the core that's rotten underneath the Fiberglas, you'll have to rip all the glass up and most probley just sweep the reminats of the core up. You can go to Chet's thread when he did his viper and see what his looked like and what it took to repair his
Since the previous owner was driving it I didn't think it was that bad but it NEEDS to be replaced. Like Bill said it will be a lot easier to remove since it is all rotten I would guess you can have it out in a weekend easy. My computer isn't playing nice but I will post a pic of a good core.
This is what is should look like. Granted this is new clean glass over the balsa but you get the point.
If it's too much for you and you want to trade back I am willing.
I think its all rotten really bad...and the fiberglass on the floor is cracked through and it all just looks like a big mess. How do i know what to remove and when i get to the bottom?
The top layer should rip out, then there will be a void where the core was stop there.
Ok, is there any less costly method to make it safe again or is about $1500 just what it takes?
That is a safe budget for the job, it can be done for a little less but if you plan for $1500 and only spend $1000 you are in a better position. It can be more if you start using composites and epoxy.
One thing to consider is after it's done you can put just about any power on it you want and be relatively safe.
- 7546 Views
Apr 09, 2017 7:23 pm
Motor how much is too much weight for a motor.
Last post by Bob Roseville MN « Feb 05, 2017 10:49 pm - 17Replies
- 30745 Views
- Last post by XcellR8
Jun 14, 2020 7:46 am
- 6298 Views
Feb 08, 2017 5:12 pm
- 5806 Views
- Last post by Watterush
Feb 20, 2017 11:09 am
- 12223 Views
Feb 23, 2017 10:55 am
