Hippie feel free to move this if you want,
I thought I would post how to remove the oil pump and install a block off plate.
First thing to do is fill your fuel tank and add oil, doing this ensures you will have oil in the event you get distracted.
Next I removed the oil tank from the boat. The oil pump will come off so that line can stay off but you will need to plug the fitting on the STBD side of the block if not it will suck air and run lean enough to burn the cyl down. I didn't take pictures of that.
Next remove the onboard oil tank and cap.
Next is the oil pump sensor at this point remove the philips ground screw you will be removing all the grounds under it.
As long as your at it might as well remove the oil pump modual shown here.
You will need to remove the green wire from the outer powre pack.
At this time you can take the oil pump arm off the carb linkage and pull the pump, plasitc adapter piece and metal pick up as well as the shaft.
This is the block off plug,I will get the part # But there are 2 a short one and a long one use the long one it holds a bushing in place.
The flat part goes twords the crankshaft. They are 8-32 x1/4 screws or bolts that hold the plate in. They are available at a hardware stoor.
This is it all off.
If I forgot something feel free to add to this, it was a while ago I did it.
mercury oil pump removal
- 6088 Views
- Last post by hustle
Jan 26, 2011 10:41 am
1981 Hustler Bandit for sale!! Fully re-done and runs fast
Last post by dnatwin « Jan 27, 2011 2:01 pm - 1Replies
- 3266 Views
- Last post by dnatwin
- 10219 Views
- Last post by ConFuseee
Jan 31, 2011 7:36 pm
- 3157 Views
Jan 29, 2011 1:40 am
- 3635 Views
Jan 29, 2011 5:17 pm
