Page 1 of 2
Vking windshield mounting
Posted: Jul 01, 2013 1:07 pm
by BQUICK
How does the windshield attach at the rear? I have the frame and a windshield on the way. Is there a channel bracket of some kind that the frame attached to?
Re: Vking windshield mounting
Posted: Jul 01, 2013 2:43 pm
There should be a notch in the deck that it sits into.
See the arrows in the picture. Click to enlarge the picture.
- frame_mount_deck.jpg (140.93 KiB) Viewed 8371 times
Hope that helps.
Posted: Jul 01, 2013 3:11 pm
by BQUICK
Yeah, I know...just screw through the rail into there? My rail has no holes.....
Posted: Jul 01, 2013 3:25 pm
Yep. If there is no screw holes you have never had a windshield mounted to it before. Use a good stainless steel self tapping screw or something. Thats what I have but the have also been pre drilled and dont over tighten then so you dont wreck the fiberglass.
Posted: Jul 01, 2013 8:59 pm
by YDOC462
curious?...... Is this a new rail and shield...if so where did you get it.
there should be a block of wood glassed in behind the notched section.
Posted: Jul 02, 2013 8:37 am
by BQUICK
It's a new rail from Hydrostrean in Tracy, CA purchased in 2000. The guy who bought it tried to install and broke the windshield they provided. Boat was sold to me with just the rail. i need a shield ....was going to go with acrylic but thinking epoxy now sice the guy broke the acrylic so easily.
Bruce
87 Vking YT, Yamaha ProV 150 now, 72 mph
BRAND NEW 1988 225+ Yamaha Excel going on, 85mph???
Posted: Jan 02, 2014 12:04 pm
by BQUICK
OK, I got an acrylic windshield, however the shape isn't the same as the rail. How do I bend the rail to fit the windshield?
Windshield is flat across the top center but the rail is round like a horseshoe.....
Posted: Jan 02, 2014 7:21 pm
by mitchielpricer
BQUICK wrote:It's a new rail from Hydrostrean in Tracy, CA purchased in 2000. The guy who bought it tried to install and broke the windshield they provided. Boat was sold to me with just the rail. i need a shield ....was going to go with acrylic but thinking epoxy now sice the guy broke the acrylic so easily.
Bruce
got my fiberglass black gel coat version installed in oct /13 looks cool the rail sits inside the lip at the upper portion of the windshield and just added little silicone along with stainless trim screws its lower than stock besides the v king looks retarded with out the windshield the shipp cost was around 550.00 littl pricey but man its cool . i will try to get some snap shots soon. gary
Posted: Jan 02, 2014 9:47 pm
by YDOC462
try sticking the top corners of windshield in first?
Posted: Jan 08, 2014 2:49 am
by 265mercman
i had my winshield built buy scott steffe in flordia at all fiberglass repairs super clean and strong i run mine with no rail at all
