Floor and stringer question
I'm getting ready to replace the core, stringers , floor and transom in my 1983 Vector. It was already removed when I got the boat. Does the floor sit on top of the stringers or is there supposed to be a space between them? Should the floor extend all the way out to the sides of the hull? I'm also trying to figure out the stringer to transom, should the stringers go all the way back against the transom? Thanks in advance
Re: Floor and stringer question
Welcome and here's a link that will benefit you. It's YDOC's bulletproof rebuild.
http://www.hydrostreamforums.com/viewtopic.php?f=13&t=909&start=60
Yes, transom knees (braces) are very desirable, although not factory.
The floor will attach to the stringers, and on a boat like a Vector the height of the stringers will determine the size of the floor.
Thanks. So I guess a little taller stringer will make the floor wider, should the floor go all the way to the sides of the hull? If so should it be glassed to the sides of the hull or just tapered into the bottom? I'm also trying to figure out how to build the bilge area where the drain plug hole is.If I make the stringers go all the way to the transom how will water that gets under floor drain out? Or should water even be able to get under the floor ?
As I understand. the Hydrostream factory changed the floor height. Taller stringers gave the most flat floor space, lower stringers made the floor attach to the inside of the v-bottom.(lower center of gravity).
btw It's a good idea to plan you fuel cell placement before you make the stringers.
Anyway, make holes in the rear of the stringer if necessary. You definitely want all the water to be able get out.
- Been thanked: 7 times
there should be a strake that is open on the inside of the hull. the rest should be filled in and glassed over. the empty strake is where the floor goes. so run a level across from strake to strake, and measure up to it for a stringer height. Im doing a stringer on core hull with no floor, so I will add stringers in the strakes that the floor used to be in. hope that is how yours is built also
what he said....the knotch in the hull on inside is called the floor register. this is where the outer edges of the floor rest. measure stringer height like aaron said and itll make stringers "touch" floors for their full length.aaron78viper wrote:there should be a strake that is open on the inside of the hull. the rest should be filled in and glassed over. the empty strake is where the floor goes. so run a level across from strake to strake, and measure up to it for a stringer height.
the stingers wont be same height all the way down. others like chet made a jig to run a router down length of stringer to get height right.
older streams had the lower floor register ........later on they raised the register making flat floor space larger..........but then you sit higher in boat. i like to be low just a thought....
What thickness marine plywood should I use for the floor?
i used 1/2" glassing bottom and top sides. you could use 1/4" long as you glassed bottom and top....would be strong as hell after glassin. all depends on how weight sensative you are trying to be.
every where i bolted or screwed something down (i.e. seats, foot pedal, gas tank, battery, etc.) i glassed in 3/4" thick strips of ply to used as mounting surface. this way NOTHING is screwed into or through floor giving potential for rot. if my strips rot.....i just pulled em up and reglass new ones in.
Great info , thanks for all the help guys. I'm sure I'll have more questions later, hope y'all dont mind helping me out !
grab a beer and a lab top and go to the "restoration" section and read read read read........tons of info and answers.
- 4424 Views
Jul 20, 2012 12:32 pm
- 4794 Views
- Last post by iqraceworks
Sep 06, 2012 5:48 pm
- 3951 Views
- Last post by Varigeo
Jul 21, 2012 11:26 am
- 12290 Views
Jul 31, 2012 6:42 pm
- 10221 Views
Jan 02, 2015 2:55 pm
