Layers of 1708 on transom
- Has thanked: 2 times
- Been thanked: 3 times
How many layers of 1708 is typically done on the inside of the transom? I have two layers on it now that both end way up in the wing. The ends are staggered as well. Also tabbed the bottom in with two layers. I also laid two layers of 1708 in before I bedded the transom. Those ends staggered as well. Should I add anymore to it before I continue on? I’m thinking/hoping that this will be enough, What do you guys think?
1977 cocoloco varmint
1988 reaction 19
1988 reaction 19
Re: Layers of 1708 on transom
When I did mine, I put a layer of CSM then one layer of 1708 then my transom if I remember right. My outter skin was still pretty thick. I used 3 layer of 1/2 inch marine ply on mine.
Mine was what I considered to be thin, but I don’t have anything to compare it to. No other streams around me with the transom ground out. I went with 3 layers of 3/4 on mine bedding in with corebond thinking that would beef things up.
1988 reaction 19
1988 reaction 19
Thats a THICK transom! Factory is only 1 1/2 inches thick. Tire your stringers into the transom with some knees and you should have no issues with hanging anything you want on there.
I tend to overthink things, probably should’ve stuck to the 1.5, Oh well. I’ll drop in some braces and call it a day then.
1988 reaction 19
1988 reaction 19
Other than the extra weight of the extra layer of ply, its not going to hurt a single thing.
Are the two layers of 1708 enough on the outside (side facing bilge) of the transom?
1988 reaction 19
1988 reaction 19
- Been thanked: 40 times
I would say yes. Make sure first layup goes another 10 inches outside each side of the transom and the second 5 inches on each side. Maybe 7 inches and 5 inches, but something like that.
Cool. I’m throwing another layer on it just to make me feel better, then calling it a day. Thanks!!!
Additional won't hurt, especially where the bolts will be is my procedure
- 7728 Views
Apr 12, 2011 9:51 am
- 2890 Views
Apr 12, 2011 10:46 pm
- 2556 Views
- Last post by frogII
Apr 11, 2011 3:39 pm
- 9281 Views
- Last post by OMCFREAK
Dec 18, 2012 9:59 pm
- 3276 Views
Apr 16, 2011 1:00 am
Users browsing this forum: No registered users and 61 guests
