About what volume of gel coat will I need to re gel the hull and the deck of a valaro?
Thx
Amount of gel coat to cover hull and deck of a valaro or v -king
Re: Amount of gel coat to cover hull and deck of a valaro or v -king
I can't help you there but in sure someone like Tony (tnelson) will chime in before too long. He just re-gelled his Viking, top and bottom. It looks stunning! He has pictures here in the resto section.
Depends on what you plan to do. I sprayed flake on my boat so I needed three total layers of gel to get it right(Base color, flake/clear, clear). If you're doing a solid color on the whole boat you could do it with one coat. Each coat took about 6-7 quarts of gel for each the hull and deck. So for a single color boat I would grab a 5 gallon pail and you should be covered. If you're doing flake its a whole new game. But figure 6-7 quarts for each layer of gel on a 18' stream. I figure I laid it down around 26-32mils, which is a bit on the heavy side.
- 8749 Views
May 08, 2013 7:16 pm
- 4320 Views
- Last post by HydrostreamWannabe
Jul 11, 2013 11:21 pm
- 4813 Views
- Last post by Brooster
May 13, 2013 9:54 pm
- 5267 Views
- Last post by cajunmerc
May 12, 2013 6:45 am
- 6929 Views
Nov 08, 2017 11:02 am
