Venus XT prop advice
Hi all, I'm new here. HAd a few HS's over the years, now the latest.
Here's my question. I need a little advice on a prop.
What I have is; A 1987 Venus XT, 1988 200 Yamaha, 6" CMC plate, Low water pickup CLE lower, torque tab, drilled exh. below cav. plate (6 holes, 5/16 ea.) and a Ballistic 25XL 4 blade prop with a solid welded hub. Prop shaft is 1-1.5" below the pad.
Currently runs 69-70 mph at 56-5700 rpm with full trim and a 2 degree positive wedge. This is with 1/2 tank and 2 people.
2 questions..I would like a better prop. Any ideas or good ones with this combo? This one slips a bit till you get it flying over 50, then you really feel it "hook up"
Ron Hill recommended a Eagle 4 blade 26 pitch.
I am going to pull the heads and mill them .050" this month. I will also put a better air intake on it.
One other thing..it burns out the rear propshaft seals in a quick hurry..I rebuilt the lower last Aug and it cooked them in very few hours use. They were shot when I got the boat too. Could it be a cooling isue with the welded hub? Water collects in the cavity and it does not flow around in any way. I just want an over the hub prop, I think it will fix it.
I have a pretty common set up I think, and would like a little comparitive data from some others on here if possible.
Thanks in advance, Ron
1990 HST / 260 EFI offshore
1987 Venus XT/ 200 Yamaha
1983 Viper II 90 Merc. triple
Re: Venus XT prop advice
Don't know a lot about set up on a venus. I know they were the fastest 20 footer. Should be simulat to a vegas. Check this out. http://www.hydrostream.org/TechTalk/TechTalk.htm
Hope it helps
Rick.
Hope it helps
Rick.
chris thomas had one, check out his vids
http://www.hydrostream.org/Videos/Videos.htm
his went 96.5 he's in the 90 mph list,
http://www.hydrostream.org/TopGuns.htm
says he used a 30" Lightning ET prop
i don't know the guy personally, but i did see his boat for sale on kijiji out in B.C.
dunno if he sold it
dunno if he sold it
I ran a 27 srx on my xt vegas with a 200 mariner for a everyday prop. I have a 24 lightning for drag racing and love it, I have thought about trying a 28 lightning but the boat funds are non existent at the moment.
Well the Vegas being a bit lighter than my Venus, I'll bet Hill is right on with the 26. Are you running a 4 blade?
Ok, I see the link. Lightning 3 blade. I think the 4 blade acts bigger due to the increased blade area. 4 blade 26 is equivalant to a 28 3 blade give or take.. I may take Hill up on his Eagle 26 4 blade from the sounds of what I'm hearing.
For all out speed I'd stick with a 3 blade, more bow lift. JMO I was thinking of getting a trophy or something like that and got talked out of it because of that reason.
I haven't tried a 4 blade yet but I want to try one out. I did have a 25 high 5 when I bought the boat with the motor bolted to the transom I liked the acceleration but haven't tried it with any setback.
i was told to try a 4 blade hoss triton once
from what i was told if i go 3 blade i might get let's say 95 mph topped out
or with a 4 blade triton the same boat might do 90 all day with just about anyone behind the wheel
chine walk isn't as bad with the 4 blade
i guess it all comes down to what you want or need
i haven't tried a 4 blade yet, doin' 90 with anyone behind the wheel sounds good, lol
triton prop blades are thinner, i would imagine a good prop for top end
http://hossprops.com/index.html
- 4175 Views
Jul 26, 2011 10:55 pm
- 4539 Views
- Last post by RedDemon
Jul 27, 2011 7:00 am
- 9715 Views
- Last post by beavertonae-21
Jul 10, 2012 6:59 am
- 4565 Views
Jul 27, 2011 9:33 am
- 3204 Views
- Last post by Lake Conroe Viper
Jul 27, 2011 6:47 pm
