Vegas set up?
Vegas set up?
I have a 91 vegas with a carb. 200 merc. I have a 12" jackplate in my shop and was wondering if anyone has tried this or close to this setup.
I'm also looking for any suggestions as to what prop has been tried.
As of now the motor is on the transome and is running a 25 pitch high five. Due to some issues I haven't and can't test yet so I'm going in blind but want to hit the water running.
Re: Vegas set up?
First a disclaimer; I'm no expert [understatement]...but I do have a Vegas w/ a 200 merc.
I notice from your other thread that you probably want to ski with this boat. Well, it will probably will never ski any better than it does as it is set up now...but who wants ski all the time?
For the XT, the general consensus is a chopper style prop. These surfacing props will give you the bow lift you will desire to fly the hull. Usually with less set back than you'll have though, so I don't what other prop might work well. I certainly don't know if you'll get good performance with your plate, but if it were mine, I would definitely give a try.
By the way, I see that you "got Merc", but do ya got solid motor mounts, tight steering, and other safety equipment?
Re: Vegas set up?
Looks like this guy is running a 4 blade cleaver on his pad V. (cool boats are lurking all over the net.)
- Has thanked: 351 times
Re: Vegas set up?
Hey, Thats a vulture just like mine. I have a bunch of pictures of it on my computer somewhere. Its one sweet stream!
Re: Vegas set up?
ok, I dont mean to hijack this thread but here ya go...
Its a 1983 Vulture. By far one of the nicest looking boats around if you ask me. I love the colors on it.
Re: Vegas set up?
Try a Trophy, They pretty good bow lift and work pretty good when surfaced too. And maybe an SRX for top end speed if you got the motor up , Stay away from Cleaver props. There only good for Top end, with Light loads. (Note: I don't have a Hydrostream Vegas just typing from what I have heard and read)
1982 Hydrostream Vandal
Currently restoring...
Re: Vegas set up?
Thanks for the responses and any imput is welcome. I'm in a odd situation and can't work on the boat yet so I'm just buying some parts.
So far I've just went through my shop and I did find another jack plate a 6" but it's not hydrolic.
I have a extra sea star pro sytem so setback will be able to be changed easy. I have ordered a set of solid mounts and a nosecone.
I work at a merc dealer so I'll check and see what we have for trophy props. Thanks again.
Re: Vegas set up?
Man, you are in an enviable position.I have a extra sea star pro sytem so setback will be able to be changed easy. I have ordered a set of solid mounts and a nosecone.
When do you think you might get it wet.
Re: Vegas set up?
I tried to "barrow" a set of dealer plates today but that didn't work. I'll se if I can take it out tommarow.
As of now it has a 25 pitch high five and is rigged with dual cable steering but if I move it back I'll need longer cables so thats why I'm going with hydrollic. That and switching jackplates sucks with cable steering.
I know it's not going to be a great ski boat but I'm just hoping for a good comprimize. I went to pick up a malibu flightcraft that a guy I worked with is selling but when I got there it was in terrible condition. Green treated wood in the transome and it wasn't all covered with glass. To add to it he was saying how to make a big wake is just pull the drain plug and let water in the hull great with exposed plywood!!!
- 3911 Views
Mar 15, 2013 2:58 pm
- 7448 Views
Mar 16, 2013 12:12 pm
- 6521 Views
Mar 17, 2013 7:30 pm
- 33Replies
- 17731 Views
- Last post by koukrapock
Mar 25, 2013 8:40 pm
- 4615 Views
Mar 18, 2013 12:19 pm
