Page 4 of 7
Posted: Jul 24, 2012 11:11 am
by bhbestcustoms
After about 45mins of grinding!
Before grinding
The CRACK
Its about 5 1/2 inches long,
Posted: Aug 08, 2012 9:23 pm
by bhbestcustoms
Posted: Aug 09, 2012 7:56 am
by Surface Scratcher
Hey guys, congratulations on the progress! Well it looks like you're gonna get to replace practically all the wood in your boat... probably more work than you expected but you'll
know everything is solid when you're done.
Two cents:
The guy that worked on the boat before y'all was a "free thinker.
When you see extra metal attached to the transom, it's usually to cover up a problem.
I would rebuild the transom back to normal height (that cut down weakens it).
Instead, find a manual jack plate, maybe a 6 inch for the 140 hp. and you'll be able to dial in the best height for your set up.
Because you'll replace the transom and the stringers (beams), you are in a great spot make the boat stronger than it was when new. Look up Chet's 77 Viper project on here. He made a simple one piece knee brace/ stringer on that rebuild.
Posted: Aug 09, 2012 11:41 am
by YDOC462
I second everything above. Looking good keep pushing!
Posted: Nov 29, 2012 7:29 pm
by 74vector
Took me a few years and TOTALLY worth it so keep at it see comments about core removal on other thread but .....one day your 74 will look like this 74......
Posted: Nov 29, 2012 10:33 pm
by 265mercman
agreed you can look at my 79 vector restore i done the knee braces also as i copied from 77viper (chet) and was strong as a ox and still is with 200 mercury pounding away i jumbed waves and all now have sold the boat and 3 years gone bye still strong no doubt keep up the good work on the recore and wood progression willl be a beautiful sight when sitting in the water
Posted: Nov 30, 2012 6:00 am
by RussF
Randy lets show then a real nice pic of your boat
- 25g3yhk.jpg (289.84 KiB) Viewed 10156 times
Posted: Nov 30, 2012 7:55 am
That thing just screams 1970's. I love it!!
Posted: Nov 30, 2012 1:57 pm
by 74vector
Hi Russ,
Thanks for adding the pics.....Geez, I wish you had your boat at the CT river! Keep me posted on that Spring trip to NY maybe I can do that. You obviously read about my near miss on the highway home.....yikes.
Randy
Posted: Nov 30, 2012 5:59 pm
by RussF
- 112a5w2.jpg (282.56 KiB) Viewed 10139 times
