i just picked up a bridgport been sitting 4 yrs was a running motor when parked disassembled looks clean has 4 steel sleeves nicsil on 3-4 cylinders with stock pistons other 4 are wiseco .20 over with steel sleeves iam needing stator and trigger and what injectors to run 77vipper maybe you can chim in for me thanks
new 240 bp injector help
Re: new 240 bp injector help
it has green injectors i pulled one out number on side is as follows 0280 150 036
can't send em to brucato and get em flowed and cleaned? lot cheaper than buying new ones
thought about that cody but these are bosch injectors iam pretty sure out of a mercedies bnz lol what they looked like gona call tony tomm and send these any ways also for back up if there sll good gona put in i suppose
Tony can clean those injectors. You need a 16 amp stator and a v6 trigger. If you need part #s let me know.
i found a v6 trigger laying around shop brand new cdi part # 134-6456-15 need stator number and was a little black box on top took it of as well had 2 red wires 1 black and 1 white maybe yellow wire bolted on top of port side top of heads and can u tell me how to hook up the fuel rail has a inlet on top and bottom doesnt have t in the middle is bottom inlet then top out to fuel pressure regulator?
- 3158 Views
Jul 12, 2010 7:14 pm
- 13270 Views
Jul 21, 2010 5:33 pm
- 3674 Views
Aug 01, 2010 10:26 pm
- 2793 Views
Jul 12, 2010 11:20 pm
- 6386 Views
- Last post by hydrojake
Aug 30, 2010 4:23 pm
