Alarm noise,beep 2.5xri efi 1994 stock,lwp
Posted: Aug 28, 2011 8:44 am
Went out yesterday and alarm noise starts beeping.Seems to get worse when hitting waves.Water pressure is 8-13psi Water temp 130-155 Engine still has oil injection and level is always full.
Replaced water/fuel separator and wire is connected.
Removed oil level sensor and ohmed.The sensor is open when level sensor is up(full)Has resistance when sensor goes down.Also ohmed both wires and they are not open.
I'm thinking that sensor is bouncing around in jug causing oil injection module to see resistance.Setting off alarm.
So i zipped tied sensor to full up level.Have not had a chance to try,maybe Wednesday.
Another problem is tach is reading high(almost double)3000rpm actual to 6000rpm on tach.It is gaffrig, and i checked grounds and tach wire from engine to tach.
I switched tach lead(gray wire) from top rectifier to bottom and will also have to wait till Wednesday to test.
What opinions do you guys have.
