Well the merc 110hp doesn't do it for me. I just got a 150hp gt mariner low water nose cone with a jack plate with set back. Should I use jack plate w the setback or just mount tight to transom? From what I've read the vector doesn't line the set back. Anyone with experiance would be a big help. I'm going to do a recore and transom this winter and doent want to make swiss cheese with a new transom. Since I don't have time this fall to try it out I thought I would just ask to find out.
vector and jack plate setback??
Re: vector and jack plate setback??
How much of a set back is that jack plate? I would say in the 4" area is a good place to start on a Vector.
Also, I would do the core and transom first seeing as you plan to redo it anyhow. It will make for a totally different boat once its done. What might have worked on a mushy boat boat may be complete opposite on a dry strong boat.
You can drill a jack plate to match the bolt pattern for your motor. Then, if you take off the jack plate, the motor will bolt right to the same holes in the transom.
- 9379 Views
Jul 28, 2018 10:15 pm
- 10187 Views
Jul 28, 2018 9:41 pm
- 8550 Views
Aug 03, 2018 10:15 pm
New to forum but grew up on st criox river with streams in the 70's
Last post by Colorado Vamp « Aug 03, 2018 12:02 pm - 4Replies
- 6875 Views
- Last post by Colorado Vamp
Aug 07, 2018 2:05 pm
- 11035 Views
- Last post by rjdubiel
Feb 17, 2019 10:57 am
