200 merc fuel pump?
200 merc fuel pump?
ok iam wanting to remove my vst fuel/vaporator system on my efi 200 mercury 95 model so there is two inlets on the top of the injection housing of which i dont know which is the inlet and the return i would assume and what psi pump do i need everyone says the holly red will suppy the motor but its a 14psi pump but everyone says to run a 39psi regulator if thats the case this pump will not supply enough fuel will it or will it
Re: 200 merc fuel pump?
I can't remember the hose routing tonight but the holley pump will not work for you. http://www.brucatosvs.com/store_components.html
ok chet i got the line routing the inlet and outlets iam just wondering bout the air lines ooff the injection housing to the vst system theres probally 5 of them may more havnt removed it yet so do i just route them back into the ones that are coming off the front half or block them off any help or diagrahm that could be showed on this would but me to being doing lol thanks i no your busy iam waiting on a part or two to come in so take your time thanks again
- 2723 Views
- Last post by blowitup
Apr 17, 2012 8:40 am
- 2625 Views
Apr 18, 2012 8:13 am
- 44Replies
- 9894 Views
- Last post by Varigeo
Apr 28, 2012 11:51 pm
- 22Replies
- 7348 Views
May 20, 2012 10:07 am
- 4243 Views
- Last post by varmint1
Apr 21, 2012 5:37 am
Users browsing this forum: No registered users and 54 guests
