I have a couple questions about the core of my Vegas. I have discovered that the back 4' of the v portion of my hull's core is pretty bad. It basically starts where the hull steps. I have that already cleaned out and ready to recore. My question is regarding the pad. I have not taken any samples, it appears to be very solid and I didn't want to have to tear out more than needed. Is the pad also balsa cored? And if so how thick? I have done work in checkmates but this is my first hydro.
87 Vegas Core Questions
Re: 87 Vegas Core Questions
The pad is cored with 1/2" bulsa. Is it a v or xt bottom?
Thanks I'll be sure to check it out...
It's an XT hull.
It's an XT hull.
It's an XT hull.
It's an XT hull.
Hate to be the guy with the bad news but assume it's bad and get it out. I don't know the years, Chet can better explain but the XT's were known to be bad. If you have rot in back you probably have more rot. If so don't be afraid to do it right. The piece of mind of knowing outweighs the time and cost. If you love the boat, you will like it more when it's lighter weight. Love to see what it looks like. Post some pictures of both the outside and anywhere the floor is up. After doing a core. you can tell pretty much from a photo where the dark spots are. Bill
Bill is correct about the piece of mind knowing all the core is good and dry.
I'm not so sure about the tx's but have heard the build quality wasn't the best on the yt's from 87-89.
- 9866 Views
- Last post by 81vector
Jul 10, 2011 10:04 pm
- 7186 Views
Feb 25, 2011 8:32 pm
- 8765 Views
Feb 20, 2011 3:02 pm
- 5220 Views
- Last post by AFR
Dec 31, 2011 7:41 am
- 3832 Views
- Last post by 87vantage
Feb 14, 2011 3:00 pm
