Im working on redoing my 2nd stream recore job,
However over the years ive been wanting a light lay up .Now i did like useing balsa in my first stream however was wandering about a glass only lay up with afew more stingers.
What do you guys think would be best and pull the hull in as light As posible.Its a viking 1978 hull and will be used for 1000 ft drag raceing only..
I have plans how to do it right now im just looking for your guys thoughts.
Any and all info is great.
To core or not
- Hydrostream Great - RIP
Re: To core or not
I would use a 1/4" bulsa core for a light boat as well as more longer stringers before I would just add glass. I would think it would take a lot of glass and matt to get the same strength of bulsa.
I understand it wouldn't be used as a lake boat but they still need to take some abuse drag racing. It's not like they call off the race due to wind and waves, we still run anyway so it's not always calm out.
I'm not a glass man so this is just a opinion.
Re: To core or not
Just glass would be way heavy. Vipers right, use thinner bulsa or foam and add stringers.
Rick.
Rick.
Re: To core or not
Thin lay up with bulsa core would be the starting plan.However i have seen them with just glass.I also think the a glass lay up would come in at more weight then the bulsa lay up.
So would you guys run stringers in the hull and add core around those or core the hull in and add stringer to the hull setting in the strings on top or the core.
and would you guy bag the core or do it just as stream done it years ago.?
The vector i recored afew years back.turned out well.and at that time i bed'd the core with hull and deck putty and wetted out one side of the core and weighted the core down while setting up.
after 3 hour of set up or so then i was able to wet out the top side of the core and glass it all down.
This was how joe at merton glass had me do it.
That vector is light and straight and runs now into the 90s with a fresh stock 2.4 150 merc.
I guess im looking for thoughts on stringers and how best to run them.
Thanks guys for all help.
Re: To core or not
I would think bagging would be the best but just if you can get good adhesion without bagging it'll be ok. I think the stringers on the vipers were on top of the core anyway??? I would go on top of the core with that one with a thin core to distribute the stresses better. My vking was different, the core around the stringers. I run a lot in lake st. clair and is concidered rough so I built mine like a brick s**t house. Still is going to be much lighter though.
- 5818 Views
Feb 09, 2013 6:13 pm
- 6118 Views
Feb 12, 2013 12:04 pm
- 6256 Views
- Last post by streamin_demon
Mar 20, 2013 12:26 pm
- 145Replies
- 42728 Views
Jan 04, 2014 10:35 pm
- 3816 Views
Feb 15, 2013 12:23 am
