Was wondering if anyone who owns a Stream has had a winch hook on the front of the boat get loose. I own a 81 Vulture and the hook is loose. I removed the base for the plug in light pole and was able to get to one of the nuts. Unfortunately the nut at the top of of the hook has vibrated off completely. I see no way to get to the top nut to install a new one. Don't want to cut the nose of the deck to get to it.
Any ideas would be much appreciated.
Thanks,Dan Twiford
Winch Hook
Re: Winch Hook
I had to sawsall the old one off of my vking and bought a repacement and had a skinny guy climb up there to mark where to
cut the top stud. Installed with large stainless washers. the top stud had to be tightened with a 12 point box end wrench. It's tight up there. West maine had the exact replacement. Hope this helps!
Rick.
Rick.
Re: Winch Hook
I need to replace/fix the one on my vulture also and I have been wondering how tyo go about it. Looks like someone butchered mine and tried to replace it but didnt due such a good job. lol
Re: Winch Hook
Mine was loose when I got my boat . I didn't eat for a week HaHa. Then I was able to squeez within arms reach. I also pulled a seat to make it easyer to start this confined space operation.
Re: Winch Hook
I was able to tighten the one on my vegas by removing the bow light and using universal joints anthe the right extensions I got on both nuts to tighten them up it must have worked they haven't come loose since.
Re: Winch Hook
Thanks for the ideas everyone...unfortuneley I could not access the top nut, tried extensions, universals etc. with no luck. I ultimately had to screw up my deck and drill a 3/4 hole right over the shank large enough to get a 9/16 slim body socket on the new nut...fixed it and am going to find a 3/4 snap in plastic plug to cover the hole. Sounds like another common problem with Streams. Too bad they didn't dab a little loc tight or resin on the threads before they mated the deck...???
1981 Vulture powered by a Merc 225
- 96903 Views
Mar 10, 2022 10:03 pm
- 118712 Views
Mar 25, 2022 2:11 pm
- 119579 Views
- 125959 Views
- 78169 Views
May 22, 2022 8:22 am
Users browsing this forum: No registered users and 112 guests
