![Image](http://i322.photobucket.com/albums/nn434/starfire440/2012-06-09184455.jpg)
Odred a new Bob's low water pick up and now looking at a jac
Re: Odred a new Bob's low water pick up and now looking at a
Boat looks nice! I see no setback there whatsoever, motor's bolted directly to the transom. That steering does look very similar to mine as well. I don't want to alarm you, but you may want to confirm it's a dual helm. As far as I've been educated, and I may be wrong, but having both cables on the same side as the motor, and running in parallel on the helm isn't the best for the performance our boats are capable of. I'll be in the market for a dual opposed dual helm setup when I can spend more money on the boat lol... Gotta put a roof on my house first....
[ Post made via BlackBerry ]![Image](http://www.hydrostreamforums.com/images/mobile/BlackBerry.png)
Hey, nice ride! ...looks very original...me like.
I, also have an XT hull, with a 4.5 in jack. I'd like a bigger one. It seems that the XT can handle a lot of set back. More set back will give you more top end but it can take some of the 'familyness' out of the boat. btw, you don't have any setback now.
So how original is that thing? Is that the original motor?![Smile :)](./images/smilies/icon_e_smile.gif)
Yes it's all original 1986 Vegas xt 200 motor .mix at 32: 1the motor has been warm over. I beleave I'm the 2nd owner of her. Looking at Venus to buy and a HST . each kid is going to have a Hydrostream . My wife's aunt has a cherry 90 Vegas with 175 Rude .Well that jack plate will be a 6'' then I'll be moving that motor around till it's right I'm 5 mile from the river the prop is a 23 pitch and balnce for the motor slip . thanks guy's for the great help as aways .
6" will work but I would go 8-10" if your cables are long enough. Like I said I have 12" on mine and as long as you're going hyd. it's easy to adjust for passenger load.
Cables for my hot foot you mean ? I have 2 stearing boxs hydrolic. I better get my fat butt under the dash and take a picture of the stearing boxs .just so I'm doing the right thing . thanks 77viper you guys are a great help .77viper wrote:6" will work but I would go 8-10" if your cables are long enough. Like I said I have 12" on mine and as long as you're going hyd. it's easy to adjust for passenger load.
Well put my new Bob's low water pickup on and put in a new water pump while I had the lower unit off thats not to bad of a job at all.Theres alot of water psi now how much water psi should I have now with the 85 200 Merc .just idling 17 psi and it go 's up to 20 something and warms up to 165 170 temp but cools down to 150 at 60 mph .I'm so pleased with Bob's low water pickup and so easy to do I didn't have the 23/65 drill but I had 21/65 drill and just took my time with the 1'' taper . and tack welded around the low water pickup then used the epoxy pertty easy to do in a weekend .I didn't plug any inlit holes on the lower uint becuse I like to use my water muffs to witerize the motor by running the motor and and fogging it .
thanks to all you guys for the great help and telling me to put in a new water pumpin and great info. Put both the lower and upper new in on the water pump .
![Boating :boating:](./images/smilies/boating.gif)
- 109840 Views
Mar 10, 2022 10:00 pm
- 132778 Views
Mar 10, 2022 10:03 pm
- 163014 Views
Mar 25, 2022 2:11 pm
- 166209 Views
- 174516 Views
