like Viper, V-king or Voyager.
The additional weight might seem disadvantageous but today's 4 stroke don't weigh excessively more than the 2 strokes so I am wondering who made the transistion, what are your experiences?
Also, anyone having tried 50-90 HP on these boats? There is a rough estimation that 60 HP is needed to lift 1000kg (2100lbs) from displacement to plane mode.
I understand that the intention of the hull design is to go faster than that, but the theory should apply in general. Thoughts on this also very much appreciated.
I am thinking of mating a 4 stroke 90HP Yamaha to a Viper, just before getting into the restoration and making the substantial purchase of the outboard it would be great to get some input,
cheers
braq
Who is running a 4 stroke on their older hydrostreams
Re: Who is running a 4 stroke on their older hydrostreams
I have an old Merc 85 on a Viper. It's OK to get out on the water and play, and it'll do about 45, but it won't get on the "step" and dance like a Hydrostream should. I think a newer 115 2-stroke would be about the minimum.
As for 4-stroke/2 stroke, I don't think a 4 is a good choice for a Hydrostream. They do weigh more, generally cost more, and don't have the "power" of a 2 stroke. What's are your reasons for selecting a 4? If you already have one and want to use it, that makes a bit more sense. If you are purchasing a motor specifficaly for a 'Stream, I would buy a 2.
- Has thanked: 13 times
When we were having trouble with the 90 merc/yamaha on my dads toon I took it off and used one of my vipers to f- with it. What a nightmare. Had to prop for holeshot or top end, could'nt get both ( I have a LOT of props) and the spongy *** motor mounts made it otherwise undrivable. Not to mention they sound like ****. BHAWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW!
I am however getting a spankin' new 115 ho e-tec for the same boat and next spring I'll keep the results posted here. I think this project is going to be a lot of fun. 75 trouble free gas sipping MPH is the goal.
I met a guy with a Viper and a 4 stroke up at Lake Place a few years back. Don't recall the HP, but it did appear to run decent. Just such an odd (and quiet) sound for a 'Stream.
I imagine they will make inroads though little by little. Never thought they would be a player in the sled market but they do now hold thier own.
Hi guys,
thanks for the input.
First and foremost it is about fuel economy, I am still dreaming about some day making the grand tour of the great lakes. Fuel economy and distance between refueling does make a whole lot of a difference then.
I am constantly in repair mode running a 1964 Mercury 1000 (at some point I will have replaced most of its parts , so I am between spending 5K for ~100HP 4 Stroke and what in the 2stroke sector?
Weight is not so much apart
320 lbs - 90hp E-Tec
261 lbs - 90hp Yamaha 2 Stroke
I'd take off those 60 lbs myself...
cheers
braqq
cheers
braqq
Navigare necesse est, vivere non necesse est
If its fuel milage I love my fuel sipping 225 etec the diff between it and my mariner 225 is night and day . Im running it on a Voyager getting 75mph at 5200rpm its not proped out to the max but it gets the job done and etecs are 2strokes.
- 6439 Views
May 01, 2013 6:03 pm
- 5892 Views
May 05, 2013 7:17 am
- 3610 Views
May 05, 2013 9:21 am
- 3528 Views
- Last post by fla.viper
May 19, 2013 11:18 am
- 7366 Views
May 08, 2013 7:16 pm
Users browsing this forum: No registered users and 118 guests
