bilge pump fitting
bilge pump fitting
hello i have a 1984 vector but i noticed the boat doesn't have a hull fitting for the bilge pump.got a new bilge pump and hose cause boat didn't have one when i got boat. i also noticed boat sits low in water in the back. was wondering if anyone knows the proper location for the hull fitting. thank you
Re: bilge pump fitting
...could be wrong but I don't think they typically installed those at the factory, so its your call. In the past, I have rigged them to dump it in the motor well. Then it would drain out from there. It worked well and I didn't have to make a hole in the side of the boat.
thanx surface scratcher i was thinking the same thing cause boat sits low in the water
- 23529 Views
Jul 09, 2009 8:09 pm
- 22254 Views
- Last post by ccrick
Jul 10, 2009 11:00 pm
- 20265 Views
- Last post by iqraceworks
Jul 17, 2009 12:33 pm
- 21773 Views
Jul 23, 2009 4:40 pm
- 18167 Views
- Last post by Maple Leaf
Jul 25, 2009 1:35 pm
