1987 Hydrostream Voyager
thinking of putting a jack plate just wondering which setback would be the best putting a new 200 ETEC Ho thank you
Re: 1987 Hydrostream Voyager
Welcome,
For top speed?
Without knowing anything else about your setup, the answer is a lot.
Both the Vpad and XT will take 10 or more, maybe a little less with a heavy motor.
For top speed?
Im running a 225 ho etec with no set back and no modds and hitting 76-78 mph 85 Voyager.
Just bought a 82 voyager 150 merc mounted direct onto transom at lowest setting, need some advice for props, I have a 17 and 25 pitch laser prop at the moment but would like to find a good all around prop 3-4 or five blade?
hits hard out of the hole,on plane like right now.guy I bought the boat off of had a 26p chopper no jack plate was ok but I think I get better performance with this prop.these boats like the prop shaft about 2 1/2 inches below the pad.i had to raise my motor when I got the boat guy had it over 4 inches below the pad world of difference.lot of info on hydrostream.org on set ups on voyager,good luck
Thanks for the info, was considering raising the motor
- 76328 Views
- Last post by Calhydro
Sep 15, 2018 6:58 pm
- 226096 Views
- 163140 Views
- 197644 Views
- 167274 Views
