new member with a 78 viper
I suspect that water will be pressured out of those holes at speed. I've never seen that before. Possibly, they first closed up the upper holes and later added the cone but didn't close the remaining holes.
Anyone else?
Anyone else?
- Has thanked: 353 times
If you have a low water pickup you are going to want to plug all of the original water pick ups on the lower. Could also cause it to pull air also possibly. You could try it as is but keep a real close eye on your water pressure and temp.
- Been thanked: 7 times
Will probably cover up the top holes. that will simplify using a hose at home when running the motor. Wondering about water pump kits and thermostats? where is a good place to buy? anything else I should know? Is there an easy way to rig up new controls to it?
well I got motivated, I know I know, I cant make up my mind... but im doing work...
- stringer1.jpg (56.86 KiB) Viewed 19702 times
- stringer2.jpg (43.92 KiB) Viewed 19702 times
- stringers.jpg (64.44 KiB) Viewed 19702 times
the seat and transom
- seat excitement.jpg (69.32 KiB) Viewed 19702 times
- hydrostream transom.jpg (42.5 KiB) Viewed 19702 times
14 inch wood steering wheel anyone? I think so
- steering wheel.jpg (45.97 KiB) Viewed 19702 times
So I've been a little busy... Haven't done all the wiring at all.. But its running! Really light and very fast for a 150.. Needs solid mounts and a jackplate.. Also need to invest in some nice gauges
- 13512190_10157038297395237_5349736639569917882_n.jpg (146.38 KiB) Viewed 19250 times
- 13533221_10157038297615237_305246267208434583_n.jpg (117.86 KiB) Viewed 19250 times
here is a link to my rig with a 2.0 running about 85. 30 cleaver and 3 inch setback with a 2:1 case and a lwp
Looks like that thing is really flyin. Very nice!
- 9902 Views
Oct 11, 2012 9:20 pm
- 10204 Views
Oct 15, 2012 9:14 pm
- 6008 Views
- Last post by triumph3434
Oct 16, 2012 11:40 pm
- 16497 Views
Oct 22, 2012 4:24 pm
- 9647 Views
Oct 23, 2012 6:54 am
