Partial recore on a vector maybe.
Re: Partial recore on a vector maybe.
Click on the attachments tab below the posting box.
You need to click on the "Full Editor & Preview" button to see the attachments tab. It's not visible under Quick Reply.
- IMG_20180611_205004115-1503x2672.jpg (838.36 KiB) Viewed 9407 times
- IMG_20180611_210151784-1503x2672.jpg (993.42 KiB) Viewed 9407 times
Got all the bad wood out. Drilled 20 holes into transom only one was damp. Polished it up with poly floor polish. Stringers are Rock solid. Was planning on laying up a layer of glass Matt after the grinding and sanding was done. I have one place where I went too deep and I can see gelcoat from inside.. then laying marine grade plywood in bottom. For the very center. Then glass again then another layer of ply between the stringers. Glass again. Glass over stringer tops. Rebuild seat box and glass it in. Prime and rattle can it.
Aldo I'm probably going g to have to have the trim pump rebuilt. It's slow as all hell. But maybe it will work better when I finish the rewiring. Steering is kind of dragging but not bad.
I think this is a vector title only says hydrostream
- 3761 Views
Sep 10, 2011 10:13 am
- 4769 Views
- Last post by silkeysak
Sep 12, 2011 6:04 pm
- 16Replies
- 10224 Views
Oct 10, 2011 10:51 am
- 3056 Views
Sep 11, 2011 10:42 pm
- 2966 Views
Sep 14, 2011 9:34 am
