Boat is a Valero and solid white.
I am trying to decide wither to paint the the underside or gel it. Can't get imron or similar paint in Canada. I did use some Interlux epoxy filler in places and wonder if that would effect the gel from adhering ?
I have some Interlux Interprotecte 2002e also which I could use as the primer.
Boat won't be left in the water for more then 24 hrs.
Gives a rough idea of area where epoxy has been used.
Paint or Gel on bottom
Re: Paint or Gel on bottom
Rolled on some gel on my Vulture. Personal preference really I guess.
- Has thanked: 3 times
How was rolling the entire area?How many coats? Have you sprayed a bottom? I was looking at th G100 for spraying but reviews were mixed.
Will rolling result in alot more sanding?
Brian Carhart rolled it on for me and the rough texture was left there. I have zero plans to sand it smooth. Lightly textured bottoms tend to help break up the water from the hull and go a little faster. Thats why you see a lot of boats might have what looks like grey or black primer on the bottom of them to rough up the bottom just a bit. I guess we'll see what happens.
Now for the top, I wouldnt roll that at all, you would be doing a lot of sanding to get it smooth. I will be doing some sanding and stuff where my splashwell was removed as that had white gel rolled on it. It wasnt a lot but I have some body work ahead of me.
- 5906 Views
- Last post by apollo12
Mar 27, 2014 11:38 am
- 8865 Views
Apr 07, 2014 5:24 pm
- 7877 Views
Mar 25, 2014 2:57 pm
- 6585 Views
Mar 29, 2014 12:19 pm
- 34660 Views
- Last post by PETEROC
Apr 15, 2014 1:08 pm
