New project- 89 Voyager
Re: New project- 89 Voyager
Well, between building a pole barn, I get a couple hours here and there to work on the boat.
Two days ago I got the seat boxes glassed in place.
Yesterday, I got the splashwell glassed in and really went to town on the inside corners where they are prone to cracking.
I glassed the tight 90* corner first, then used structural fiberglass putty to make the new radius, then more glass. Mat and three layers of 1708
- 963ADE66-8523-4EFC-9D5E-F00D67D0D1D1.jpeg (101.16 KiB) Viewed 5760 times
- 42B654B7-D407-4FF7-917A-DB2F1453A07F.jpeg (128.68 KiB) Viewed 5760 times
- 314EAA9B-6BE2-4486-8285-2B311DEC64DA.jpeg (130.87 KiB) Viewed 5760 times
- C7E639F3-8243-4BE7-B160-F8619F56493F.jpeg (114.13 KiB) Viewed 5760 times
- 6F48A757-2A64-43D2-9934-FFE2FC15D7C6.jpeg (104.92 KiB) Viewed 5760 times
- 33C8DE5E-38B8-4AB2-8EAD-A453DE18BF00.jpeg (128.84 KiB) Viewed 5760 times
Today I got the micro balloon putty on and faired out.
- E650FD4F-4CBF-4914-85AC-F91D34DB97DC.jpeg (2.25 MiB) Viewed 5755 times
- FA502C29-448E-4D0E-A57D-C15FC5F27076.jpeg (2.65 MiB) Viewed 5755 times
I get a kick out of seeing the fairing putty fill in where the grinding disk hit a bit deep. Mine was covered in marks like that after block sanding the primer. Looking forward to the finished results.
Yesterday, while letting fairing putty dry, I made a “doo-dad” for the hydraulic steering hoses. The 3” opening was just too large to have just two hoses come out.
I shaped some foam and glassed up, shaped and ready for black gelcoat.
- 29E29B43-B3BD-4EB3-BEAE-9FF9A6CF7A5D.jpeg (1.64 MiB) Viewed 5738 times
- A5AB0420-B747-495C-B993-3DD7A3C221C2.jpeg (2.6 MiB) Viewed 5738 times
- 266F16D6-86C6-4494-86DB-8BFE768024EC.jpeg (2.2 MiB) Viewed 5738 times
- BB280765-DCBF-4125-9EBA-FA128A404F81.jpeg (1.7 MiB) Viewed 5738 times
Got the black gelcoat sprayed.
- 80CA5933-8CFD-4DAD-A56F-B93CF83435F4.jpeg (2.39 MiB) Viewed 5733 times
- AAFFB919-C9A9-4F7E-8D67-EF8028582C03.jpeg (2.27 MiB) Viewed 5733 times
- C2AF1AF1-8DA8-4FA6-8518-2D2BCA321385.jpeg (2.37 MiB) Viewed 5733 times
Yesterday I decided to make a swim step.
David Fatov got me measurements off his Voyager.
I leveled the hull and got my transom angle.
I am going to make fiberglass L-brackets to save some $$.
Cut a piece of foam to the shape, hot glued strips on for sides, silicone the inside corners for the radius I liked,waxed and laid up.
Got about 6 hours into this project.
- E37A7735-0EFB-41B6-BD23-F7D0E7989ACA.jpeg (490.9 KiB) Viewed 5732 times
- 0906EE46-A684-41AE-9A4E-0E0B07CD1335.jpeg (176 KiB) Viewed 5732 times
- 51CB5EEC-C484-414F-AD0A-67B5F3768C1D.jpeg (2.14 MiB) Viewed 5732 times
- DC516F7D-6CAF-4DAB-9558-CB17B1BB328C.jpeg (2.67 MiB) Viewed 5732 times
- 26849C30-A8C7-4025-8669-4FCA248269AA.jpeg (2.44 MiB) Viewed 5732 times
- BF16F60C-CA13-4FA4-B38F-2F98D23E6321.jpeg (2.44 MiB) Viewed 5732 times
- AB97A170-8518-45AC-AF9E-B169911E748C.jpeg (2.72 MiB) Viewed 5732 times
- 38D976E6-E5CD-4807-9E19-BC93B6E0DFED.jpeg (2.94 MiB) Viewed 5732 times
- Has thanked: 351 times
Looking great Ron! Lots of cool ideas for sure.
Thanks Kevin!!!
Forgot to add that I filled in a 3” gauge hole and the windshield screw holes and re-gelled these areas.
The windshield will get re-mounted and laid back like the 1990 and newer Voyagers.
- 949F1FEF-9F4A-4374-B02A-A914A0B88DA6.jpeg (2.06 MiB) Viewed 5726 times
- D0A3BB57-9787-4102-B136-AEBE53606F75.jpeg (1.45 MiB) Viewed 5726 times
- 32064E3A-30D0-4A38-8E57-FD533FA32563.jpeg (1.65 MiB) Viewed 5726 times
- 2F870D0B-9B31-4F62-AA63-2AE2CB0C2A6D.jpeg (2.45 MiB) Viewed 5726 times
- F3CEDD77-4211-4CE7-AB53-29E32AE9C203.jpeg (1.95 MiB) Viewed 5726 times
Today I took the swim step Out of the mold, did some very minor touch ups and re- shot it. I’ll pull a nice mold off this.
- B2C39B51-698D-4FB0-8016-B84526CBA358.jpeg (1.53 MiB) Viewed 5724 times
- BF6C52D5-94F2-45C2-B0FB-F1FA9BCFC85D.jpeg (2.2 MiB) Viewed 5724 times
Spent 8 hours wet sanding and buffing the black on the back .
400,600,800,1000,1200 wet sand.
You can really tell when you hit 1000 grit. Starts to get a shine!!
I have a 6 step process that works great for dark colors.
The last 4 steps use a random orbit so no swirl marks show.
- 25023F98-9807-47DA-A887-C73453D67B16.jpeg (2.49 MiB) Viewed 5723 times
- D0CA96E7-8AD7-4F4F-A404-A050E568B849.jpeg (2.75 MiB) Viewed 5723 times
- A4CF67DC-B5F5-4D89-BDF4-6DA38FE3ED41.jpeg (2.79 MiB) Viewed 5723 times
- 9401E45A-8E9D-496E-8BD8-430E47D1C696.jpeg (2.85 MiB) Viewed 5723 times
- 24F75CCA-B151-427F-9ADD-B123A76E355F.jpeg (2.75 MiB) Viewed 5723 times
- 90E3CCA8-F222-4D02-9718-5D4C27443196.jpeg (2.59 MiB) Viewed 5723 times
- 6A97C22D-157F-4D1A-A1A3-B03E542FAAB2.jpeg (2.62 MiB) Viewed 5723 times
- 4440 Views
Apr 23, 2011 9:07 am
- 5326 Views
- Last post by Sonik
Apr 24, 2011 9:37 pm
- 3964 Views
- Last post by vectorpilot
Apr 30, 2011 6:20 pm
- 3897 Views
- Last post by Rut311969
Apr 25, 2011 5:01 pm
- 5015 Views
- Last post by ConFuseee
Jan 18, 2012 9:37 am
