Building interior from scratch
Got my 1/4” staples so I could assemble the side panels.
Turned out great.
Turned out great.
- DF59541F-3958-4CA1-B1BE-80C22127D0F7.jpeg (69.91 KiB) Viewed 24852 times
- C2E61BC4-4AA4-4D70-A023-A83290E45017.jpeg (103.99 KiB) Viewed 24852 times
- 64A09D58-E809-4712-9DA2-FA3A3FBB2779.jpeg (104.06 KiB) Viewed 24852 times
Puttering away still.
Working on the rear seat bottom. Getting the stitch lines to align is time consuming.
I need to get some “pull fabric “ before I can install the cover.
This is a non stretch fabric that pulls the bolster down to the base.
I loosely slipped the cover on and am happy at the initial fit.
The steamer is coming down from Alaska so the wrinkle in the armrest should come out. ( in case you noticed it).
- 6051A4B7-73A0-4726-AFF5-1E1CA80E2783.jpeg (81.54 KiB) Viewed 24847 times
- Has thanked: 350 times
Wow! Looking great Ron! I should send you a few seats. lol
Dang Ron. You're really starting to tempt me into doing mine now. I'm starting to loose confidence that the shop I initially talked to will complete mine in time.
Haa! I wish I could help everyone out. Truly!!
It’s very rewarding but I’m slow.
Got the rear seat bottom fitted.
Going to finish the back side of the backrest next.
Finish stapling, trim edge, put on white screen material and “hide-em” to cover staples.
- 87DA1250-A533-452F-BDA2-BE70E4C8156E.jpeg (49.77 KiB) Viewed 24839 times
- 567784FD-898A-431C-979F-31339DF2B095.jpeg (91.11 KiB) Viewed 24839 times
- 22458443-489B-4321-A327-73146C67D972.jpeg (78.25 KiB) Viewed 24839 times
- D54C2C4F-4336-4B96-B6BD-9B9D7BBBA248.jpeg (98.28 KiB) Viewed 24839 times
That looks great Ron! Im with Tony. I might have to try my hand at doing my own.
Thanks guys! I really appreciate it.
Here’s the back trimmed out. Really cleans up the back when the rear hatch is open.
- F1979322-E40D-48EE-B589-C644442D9F3D.jpeg (87.12 KiB) Viewed 24837 times
- 7306FD5C-F354-4CDA-AB33-FACE4D92EA83.jpeg (95.65 KiB) Viewed 24837 times
- 444E0C24-4365-432B-8D95-51743E7A0328.jpeg (90.99 KiB) Viewed 24837 times
I spent the day making windlace to run the perimeter of the side panels. And stitching up the rear hatch area.
I can’t staple it till I get the rear side panels on then rear seat set in. THEN I can align the stitching.
I didn’t think about the bulk when folding the edges.
When I drilled the panels for the clips, I had the bare wood against the boat. Now with the extra material. ( bow side panels), the push pins won't align . I’m going to cut them off and put in rivet nuts with studs. Then I can slot the holes in the fiberglass and use nuts.
- E2AA2EED-7E1E-4D4F-B167-4EC6885F6DD1.jpeg (65.89 KiB) Viewed 24834 times
- 46BB2A83-61D2-4F10-91A1-A2E7F5BA2ACC.jpeg (69.34 KiB) Viewed 24834 times
- 764ACB64-7DDB-4A4C-9B16-CC97F1EB3D2C.jpeg (82.79 KiB) Viewed 24834 times
- D269324C-6783-42DA-A2D1-B8ABB57FEABE.jpeg (73.2 KiB) Viewed 24834 times
- DF386AE2-A01F-48A4-8C4F-687232227445.jpeg (97.85 KiB) Viewed 24834 times
- 4C0D88A0-D994-4B91-B29B-104E9ABF72DB.jpeg (80.06 KiB) Viewed 24834 times
- 5CB3E12F-2D10-4F83-AC2B-DBCB45671C7B.jpeg (71.26 KiB) Viewed 24834 times
- A87419EF-EF94-4EC5-90F9-EBB0BCD91B08.jpeg (58.16 KiB) Viewed 24834 times
This is 8 hours work.
Front buckets-
Building center section first working outward.
Front buckets-
- EE0DE402-00D7-420E-9A9F-A2004EB287D9.jpeg (76.15 KiB) Viewed 24830 times
- 6A1FF398-8236-439A-8E81-474426642647.jpeg (82.98 KiB) Viewed 24830 times
- E19A7A78-0482-459C-8144-CAD8DBAFD249.jpeg (63.05 KiB) Viewed 24830 times
- DC84273D-E720-4124-B8ED-162DB2A3A91F.jpeg (63.47 KiB) Viewed 24830 times
- F7087391-BAE6-40D7-A02E-2732C4F633A7.jpeg (72.44 KiB) Viewed 24830 times
- 35E33B1A-5512-4B9A-8048-A754BF19770F.jpeg (67.56 KiB) Viewed 24830 times
- 0A797DDB-460C-4FD1-9CB3-22A82CE4E375.jpeg (63.14 KiB) Viewed 24830 times
- 1DE7C619-F717-42AB-91F0-96A944B6FB11.jpeg (67.18 KiB) Viewed 24830 times
- BE68BFAC-B41C-4B57-AFED-8154C7402E13.jpeg (84.88 KiB) Viewed 24830 times
- FD176336-2004-44D4-B97D-070E78C80801.jpeg (83.85 KiB) Viewed 24830 times
Got the covers on the front seat shells. Overall not a bad fit.
I’ll get the steamer fired up and see if I can work out some of the wrinkles.
- 1717E365-3055-498C-9060-5A5A7B9973F9.jpeg (79.26 KiB) Viewed 24826 times
- 2724 Views
- Last post by varmint1
Oct 16, 2010 8:18 pm
- 2860 Views
Oct 17, 2010 2:11 pm
- 52Replies
- 53111 Views
Feb 27, 2012 6:56 pm
- 21Replies
- 10378 Views
Oct 24, 2010 11:59 am
- 2449 Views
Oct 18, 2010 9:03 pm
