Got the putty sanded and two coats of some scrap gelcoat sprayed over the filler.
Spent 7 hours wet sanding the gelcoat with 180 grit.
Time to mask and start spraying.
- C64945C2-5F2E-4FA0-AB9C-34800E350A13.jpeg (63.09 KiB) Viewed 33228 times
- 27E4A636-BFEF-455E-8637-70204FF37F0B.jpeg (61.19 KiB) Viewed 33228 times
- 76BC02D4-6C5D-4DDB-916B-E87EE2986B4B.jpeg (124.64 KiB) Viewed 33228 times
- 6E0D4D68-2C60-42BE-95B3-EAF007B22AB0.jpeg (110.49 KiB) Viewed 33228 times
- 17690B72-CDFA-46BE-A341-E993CE4BB19C.jpeg (109.52 KiB) Viewed 33228 times
- 4C192EAA-E7BF-4788-9C15-F21DBB1ABC87.jpeg (102.53 KiB) Viewed 33228 times
- 00458B18-EA75-4D6B-9395-D1F496D941AC.jpeg (106.77 KiB) Viewed 33228 times
- 38635E41-5037-4EBA-932A-43938FBC54F1.jpeg (117.1 KiB) Viewed 33228 times
- D75DFAE8-D279-47E9-B775-A46C1C5D9427.jpeg (87.67 KiB) Viewed 33228 times
- E26F204C-70DB-42CD-BDC5-A8C10C1758D8.jpeg (83.99 KiB) Viewed 33228 times
- 0855A8EB-5C71-4B88-80D9-3E76960150C8.jpeg (83.31 KiB) Viewed 33228 times
- 0B366BA5-496F-49A4-8CFB-62C68DAB4CAC.jpeg (99.1 KiB) Viewed 33228 times
- 087D6188-567F-47A0-9933-BB43936EDB07.jpeg (97.71 KiB) Viewed 33228 times
- A6C182AA-123C-4D6C-A6C2-C4F1D64CEE9B.jpeg (133.49 KiB) Viewed 33228 times
First color is on.
Straight white gel to cover filler then three coats white gel 50:50 with Dura Tec additive.
Sprays out like car paint.
- F86004B4-5F9A-4E85-80A1-6F116D7DF679.jpeg (273.67 KiB) Viewed 33220 times
- 41905FB5-990E-41D1-82CE-01379E093773.jpeg (281.68 KiB) Viewed 33220 times
- 4C0FC939-3182-49B5-B0A0-6157A4DA2485.jpeg (253.04 KiB) Viewed 33220 times
- 1A3F46EC-6C22-4538-B9A6-0B03CD2243C9.jpeg (281.38 KiB) Viewed 33220 times
- E8123CC6-387C-48C8-80E0-4DB8AF5E26E3.jpeg (276.56 KiB) Viewed 33220 times
Spent a couple hours covering the white and outlining the red. Got the red sprayed and edge tape removed.
Wrapping the top edge of the windscreen.
Sides are thin enough that the glass doesn’t want to roll over the top so some putty was put on the top edge as the 1708 was rolled over. No air bubbles and formed nicely.
- D295FB9F-CA83-4A72-8EDE-3789022BE41A.jpeg (274.19 KiB) Viewed 33200 times
- 6469B9D4-3A80-4FD8-8A6D-CC7EBA857C44.jpeg (399.84 KiB) Viewed 33200 times
- 7EADD5BE-D446-4E84-8EF2-5234A951AC77.jpeg (291.7 KiB) Viewed 33200 times
- 57690A43-B325-4502-8A27-9076E899B550.jpeg (341.12 KiB) Viewed 33200 times
- 4BABFDCD-02A9-46FD-821C-331FAE32FD06.jpeg (425.21 KiB) Viewed 33200 times
- 9CF7B499-15F0-4C8E-B5AC-973A7C11F4C2.jpeg (366.14 KiB) Viewed 33200 times
- 7D3BB229-C49A-45D8-865C-11CEC7C68FBC.jpeg (242.18 KiB) Viewed 33200 times
- 12E6DCA8-F442-4EC1-9BC2-5667BCE3D56A.jpeg (314.2 KiB) Viewed 33200 times
- B0DE48F5-D449-4901-A505-8C1E753D1915.jpeg (419.24 KiB) Viewed 33200 times
- A6741C18-CA17-4A7C-A3FF-756BED637F48.jpeg (255.02 KiB) Viewed 33200 times
- 3233EAA6-8D36-4C38-A2B2-B53155664162.jpeg (261.75 KiB) Viewed 33200 times
Looking great that’s the pain of the project tape lines only to tape more and wait.
Yep, that’s it.
Got the light gray on this morning. Pictures look the same as before but they’re not . Lol!!
Had some extra gel in the gun. Rather than dump it, I added some thickener and made putty for the windscreen.
- 663A37B2-C6F3-4F7F-B372-D7AACE32C84F.jpeg (299.7 KiB) Viewed 33180 times
- D9ACA4AD-D093-485E-A863-49C46EB06EB0.jpeg (321.92 KiB) Viewed 33180 times
- C89D2007-069B-4B75-AA21-B6C3418720C6.jpeg (307.44 KiB) Viewed 33180 times
- 698FE84E-925D-4DCF-BB1B-40AC01BFBC0B.jpeg (256.99 KiB) Viewed 33180 times
- 0F1C07E5-C121-4DF5-A032-D847DA2FCDD8.jpeg (250.31 KiB) Viewed 33180 times
- 458B4A70-2E04-42A6-A608-CF832187E4FE.jpeg (364.33 KiB) Viewed 33180 times
Medium gray went on with no issues.
Another small batch of gelcoat putty was put on windscreen.
After I mask each color, I go over the area with 180 grit again just to make sure I have good “tooth”.
- 0148ACC8-442F-40F4-8E6A-278E91C30EFF.jpeg (96.97 KiB) Viewed 33158 times
- 44289E81-D16B-4A79-9474-2E4F83407321.jpeg (100.88 KiB) Viewed 33158 times
- 92734A29-8A1A-4622-B5EC-6E273F54565B.jpeg (106.73 KiB) Viewed 33158 times
Last of the stripes (Dark gray) on this morning.
Wet sanded all black area again and got rub rail perimeter masked off.
Stern D-rings were loosened and pulled out so gel can get behind them.
Drain tubes are pulled and holes plugged off.
- 11773AD7-C0E9-4714-A6E6-BDC260B443DF.jpeg (275.28 KiB) Viewed 33143 times
- CE5EEA10-C123-4563-B6D0-4746201E293B.jpeg (335.41 KiB) Viewed 33143 times
- 898477B1-D84E-489F-80BB-3A3EE280115F.jpeg (299.5 KiB) Viewed 33143 times
- 1EB39CE8-A752-4C51-B324-9A90605EBCF3.jpeg (287.85 KiB) Viewed 33143 times
Black went on and stripes unmasked.
Hopefully tomorrow I can wet sand and spray the clear.
- 06D1D84C-FCA0-4A5C-92DB-86A421DF7796.jpeg (75.27 KiB) Viewed 33127 times
- 0EDB55F5-3FF4-4830-B455-3EDC670D617B.jpeg (89.79 KiB) Viewed 33127 times
- D30511D1-0ACE-435A-85F8-8874EE20D2E1.jpeg (106.22 KiB) Viewed 33127 times
- C0C18676-94A4-4FDE-B2D1-75F8EF2B998A.jpeg (102.33 KiB) Viewed 33127 times
- A306B28A-5058-4DF7-A263-767760A43CCF.jpeg (104.67 KiB) Viewed 33127 times
- 4DA99E43-0066-4C8C-B12E-7511DEE89D53.jpeg (97.32 KiB) Viewed 33127 times
- 80F6204B-E6B1-431D-87D8-66BDD1C5CD3C.jpeg (124.6 KiB) Viewed 33127 times
- Has thanked: 351 times
Thing is going to look like new!
Today I wet sanded the stripes flat and got two coats of clear on.
I’ve been rolling the boat outside to spray then promptly rolling it back in. Saves making a booth. It’s bright, no dust, no bugs. Well, today a few bugs were emerging and decided to land in the clear.
I was hoping to not sand anymore on the hull but such is life….
- 66B86660-FFDA-41DC-AD8B-01E3202CD83A.jpeg (233.55 KiB) Viewed 33114 times
- 5C7B5A45-3E44-46CB-B60D-2E7788A79B4D.jpeg (244.28 KiB) Viewed 33114 times
- 03096EF3-FF53-42FC-9893-3AC9A22EB603.jpeg (234.93 KiB) Viewed 33114 times
- DAA25653-515D-425E-A1D4-DBB502CF080A.jpeg (328.74 KiB) Viewed 33114 times
- 38A67FEA-0BEB-4A36-BE9B-F3ECE84DB149.jpeg (291.41 KiB) Viewed 33114 times
- 194469 Views
- 140246 Views
- 169893 Views
- 143819 Views
- 91517 Views
- Last post by msethsmile+
Dec 12, 2018 10:24 am
