Hi there,
I am a new V-King owner...my boat came with a Land & Sea jackplate and the previous owner informed me that it had been set too high for winter storage. Is there a general guideline of how high to setup your jackplate with this boat?
The motor for the jackplate is broken and so I only have one chance to set it at a good height manually until this gets fixed - I need to get it right so I can run it this weekend!
V-King jackplate
Re: V-King jackplate
put it 2 inches below the pad to be safe, and then you can carry weight in the boat, and run pretty fast, too.
Thanks for your response JETMORE - which part of the engine am I measuring to be 2 inches below the pad, nose cone? skeg?
you will be very safe if you run the top of the prop shaft two inches below the pad. make sure you take the measurement with the shaft running parallel to the pad by using a straight edge from a foot up the pad and toward the motor. make sense? play with the trim till you get it parallel. if you are not going to have any passengers in the boat, you can go 1 1/2 inches below pad. do yourself a favor, and plug the top hole or two on the water inlets. this way you will suck water better and less air. scratch up the inlet holes to get to bare metal, and put a simple thing like marine tex or jb weld in it. harden and sand. if you want to go higher, get a wp gauge.
Sounds good, and yes I understood everything except what do you mean by top of prop shaft?
On a side note, the boat is already equipped with a wp gauge.
- 4628 Views
- Last post by Sonik
May 23, 2012 11:13 am
- 15Replies
- 11822 Views
Jan 29, 2013 8:32 pm
- 9653 Views
- Last post by silkeysak
Jun 01, 2012 6:57 pm
- 13392 Views
May 02, 2013 6:26 pm
- 4390 Views
- Last post by JUPITER VALERO
May 26, 2012 7:56 am
