I am recoring a 1991 Canadian Edition V-King. The old core was not laid out as expected.
There was a layer of Balsa in the pad. This strip is 8' long (from the drain hole) and is the same length as the stringers and the other two strips of core. The other 2 strips are located outboard and separate from the core in the pad. They are separated from the pad by about 4". These strips are about 8" wide. All the basla appeared to be 1/2".
In summary, 3 strips of core, each about 8" wide, 4" between strips, strips and stringers 8 feet long.
Maybe this matters. There is no foot well. Floor was flat right up to the block of wood in the bow. No bulkheads or stringers ahead of the seats.
The core layout seems very minimal. Only 16 square feet of balsa.
Could this be original? Possibly a recore?
V-King Core Question
Re: V-King Core Question
Probably original, my Vision was laid up the same when I had it torn apart.
- Has thanked: 351 times
This is how the VKings core is. The Vulture is like that as well. The Vector and Viper have a lot more core in them.
Take a look at this and the last picture you will see Tonys VKing and how the core is. https://www.hydrostreamforums.com/the-core-what-is-it-and-where-it-is
Hope that helps.
Hope that helps.
Yes, that helps. I still find it strange that there were no bulkheads, stringers or core forward of the front seats. I guess the floor was the reinforcement.
Tony's build is my reference. He did an amazing job. Great pictures and video.
I wouldnt say there weren't any, just not on the stringers. There was up in the bow that also doubled as an air box from the factory. Some people get rid of them and just put a bulkhead there. I put the "air box" back in my Vulture (exact same core layout as the VKing) when I did the core and stuff. There is also one at front of the floor as well with small holes to let water drain.
- Been thanked: 40 times
Here is mine.
- IMAG0541.jpg (205.44 KiB) Viewed 7628 times
- IMAG0544.jpg (277.55 KiB) Viewed 7628 times
- 94540 Views
Feb 22, 2019 11:52 am
- 202353 Views
Dec 13, 2019 7:07 pm
- 81362 Views
Feb 24, 2019 10:11 am
- 103338 Views
- Last post by CleanV-King
Dec 29, 2020 11:32 pm
- 92808 Views
- Last post by dehydrated
Mar 08, 2019 11:15 am
