Running out of gas
Posted: Sep 16, 2010 4:02 pm
At speed (usually 4000rpm & up) my carb 2.4 starts to run out of gas. It seems to loose one carb at a time. Then, when I stop the problem goes away for a while. By the time I can get to the primer bulb, it is full, but I really don't know what it's like when the problem occurs.
Also, I've heard that fuel line can collapse under suction. However, I replaced the line with automotive fuel line about 2 years ago. I also replaced the fuel pump diaphragm 2 tears ago. Ive checked it recently and it's look like new.
Where should I start?
Thanks
Thanks
