I'm pulling my factory rail off and replacing it with the rail from taco marine
http://tacomarine.com/product/V11-3161/1-1-8-x-1-1-4-Sandwich-Style-Flexible-Rub-Rail
Since the factory rail that held the two halves together is gone how should i attach them to each other?
Will the insert in that rail with screws every 6" be sufficient?
Attach top side to hull
Re: Attach top side to hull
Check out proprider's posts here. He shows how he rebonded the deck to the hull after he split his Viper.
http://www.hydrostreamforums.com/viewtopic.php?f=13&t=2090&start=150
I've heard of guys just using 3M 5200. With a good bond that stuff will never separate. (But I wouldn't trust it 100%)
I'm probably gonna do something similar. Rebond with 5200, rivets every 8 inches, then new rubrail with screws through the insert.
But also add strips of glass to the inside seam as well.
- 76295 Views
- Last post by Calhydro
Sep 15, 2018 6:58 pm
- 226015 Views
- 163062 Views
- 197542 Views
- 167200 Views
