Viper help
Viper help
Hey guys!
My top speed has dropped,
I put the fin on it = 48mph
Removed jack plate =44mph
Prop is a 23p
Motor is a 115hp mercruiser
I'm guessing jackplate, other things could help me.
Prop is a 23p
- image.jpg (123.65 KiB) Viewed 9619 times
Re: Viper help
Try tech talk on the Hydrostream history page. I set up a vector from the info in there. Spot on I'm sure there's was more but no trial and error
Viper help
I have a viper. After installing trim tabs on the hull the porposing and handling issues are gone. It only runs 46 with an 80hp triple, but was miserable without them.
Chine walk is more than likely steering related. Loose mounts, side to side slop and too low of a motor height will contribute to that.
Here's mine with the tabs back on. I had removed them to fill and re drill the holes, which were loose.
If I had another set of tabs, I'd send them. I'm all out of the run we made. I have the dimensions though. [ Post made via iPad ]
1990 HST / 260 EFI offshore
1987 Venus XT/ 200 Yamaha
1983 Viper II 90 Merc. triple
- Been thanked: 7 times
Re: Viper help
Hows the viper doing? I would say put the jackplate back on, if you want to go fast get a 2.0 150 or bigger 2.4 motors. 6 inch jackplate and a cleaver work great
Re: Viper help
No real luck with the viper . Don't have the money to be trying expensive things and purchasing jack plates and such. Specially if it's not 100% fixed after that. Right now I just cruze around 45 mph, not on the pad, it's too sketchy with the setup on it.
Re: Viper help
Welcome back! Now with that, Sell that 6" plate and see if you can find a 2" or a 4" plate for it (My opinion 6" is way too much for a viper) and do like Ron said, maybe try some trim tabs. Also, make sure everything with the steering is nice and tight.
Re: Viper help
ill bet you can get that 115 going a whole lot better than 45. given the limited weight and power i would say a 6 inch set back jack plate would be great, and something like a 24 pitch or 26 pitch should get you going good. a decent steering system should help you get control of that thing. what do you have going on with it now? anything we can help you with?
Re: Viper help
Well.........before the internet was invented we ran Vipers 70 mph with inlines and NO jackplate. But I guess that don't count
Re: Viper help
Somebody forgot to tell Joe Sauer he needed a jackplate to go fast
Re: Viper help
You forget though that back before the internet was invented, GPS didn't exist either.
"My pitot speedometer bounced to 70 when I went over that wave! Let's just go with that!"
- 3234 Views
- Last post by Rut311969
Mar 30, 2012 7:41 pm
- 3270 Views
- Last post by LSaupe
Mar 31, 2012 1:40 pm
- 55Replies
- 29038 Views
- Last post by varmint1
Apr 16, 2012 6:54 am
Central Minnesota/St.Cloud area Hydrostream owners?
Last post by 79ViperInProgress « Apr 01, 2012 11:07 pm - 4Replies
- 4528 Views
- Last post by rev.ronnie
Apr 05, 2012 3:18 am
- 3810 Views
Apr 02, 2012 8:25 am
