I have a 79 vector with the steering wheel in the center! Would 16" cables be the right length?
Is this correct?
Re: Is this correct?
I'm assuming you ether can't read the old cable or don't have one to measure. There is a procedure to measuring steering cable length but I can't for the life of me remember it. I can look at work tomorrow and see what i can find. Ether way it sucks because I haven't found a definite way to make sure it's the right size the first time without reading off the old cable.
What are they referring to when it says "thru tilt tube type steering"? Don't know all the terminology
Alan
'79 Vector Work In Progress
The tilt tube is the pipe that the steering cable goes thru, (the sheathing attaches to the tube). the tube is also the hinge that the engine pivots from (for trim, not steering).
Back, I guess, in the early 70's manufactures all went to this. Before that, the cable sheathing was often mounted to the transom and the steering cable was attached to the motors tiller arm.
Clear as mud?
Clear as mud?
Yep clear as mud....lol! Tells me what I need to know. Thank you. Just wanted to be sure which measurement to use.
Alan
- 7707 Views
Dec 03, 2020 8:36 pm
- 8473 Views
- Last post by msethsmile+
Nov 10, 2020 11:57 am
- 9204 Views
Jun 24, 2021 11:42 am
- 13155 Views
Dec 02, 2020 5:44 pm
- 7262 Views
- Last post by Kuzer
Oct 08, 2020 5:39 pm
