jack plate question
jack plate question
i got this jack plate when i bought my viper. i am planning on replaceing the manual plate on the virage with it. i dont have a pump and was wondering if any pump from a hydrulic supply store would work, and how much psi it will need? ive also included a couple of pics of the viper with the new transom. iv got the core material, just haveing too much fun with the virage to even think about the viper.
tx, mike
tx, mike
- parts 001 (Copy).JPG (137 KiB) Viewed 4854 times
- parts 005 (Copy).JPG (128.4 KiB) Viewed 4854 times
- parts 004 (Copy).JPG (186.03 KiB) Viewed 4854 times
Re: jack plate question
i also read some where the stage 2 hull runs best with 8 inches of set back. this plate is only 5 1/2. would it be worth modifying it before i install it? is the extra 2 1/2 inches worth it?
Just install a setback bracket between the jack plate and the hull. I have a 10" setback (rapid jack) and a 4" hyd. lift behind it. Works great.
1990 HST / 260 EFI offshore
1987 Venus XT/ 200 Yamaha
1983 Viper II 90 Merc. triple
Hydraulic pressure is force over area, or weight you want to lift over square inch displacement of your hydraulic cylinder. Just figure out total weight of engine and related parts over cylinder displacement (pi R squared....), this will give you minimum psi needed to lift
[ Post made via BlackBerry ]
That just gave me a headache.idvette wrote:Hydraulic pressure is force over area, or weight you want to lift over square inch displacement of your hydraulic cylinder. Just figure out total weight of engine and related parts over cylinder displacement (pi R squared....), this will give you minimum psi needed to lift
I could have put some numbers in there as an example, but I'm feelin' lazy lol
Put an alpha trim pump on it and run it. Mine jacks faster than a Benz in Brooklyn.
rev.ronnie wrote:Put an alpha trim pump on it and run it. Mine jacks faster than a Benz in Brooklyn.
That's profilin........and profilin is wrong!!! Lmao
Alan
'79 Vector Work In Progress
thanks man, i see u got a 260 off shore on your hst. i have a 99 merc 250efi blue water on my fishing boat. the law made it not worth fishing off shore. i want to use this motor on my virage what kind of lower unit are u useing? my motor is so big i cant imagion it on the virage. this motor pushes my 1973 24' seabird 42 on gps with 5 adults bait, food, and tackle. im almost afraid to put it on a 18' tunnel.rev.ronnie wrote:Put an alpha trim pump on it and run it. Mine jacks faster than a Benz in Brooklyn.
I'm not real familiar with that motor, but if it is heavy, the more you set it back, the more it will want to swamp the boat..
I'm using a CLE with a Bobs Bigfoot. 1.87 gear.
- 161775 Views
Jan 29, 2021 9:17 pm
- 131135 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 223807 Views
Jun 03, 2021 11:12 pm
- 60510 Views
Feb 17, 2021 9:22 am
- 49140 Views
Mar 01, 2021 6:53 pm
