idle timing and tps how too
ok got the timing on the 200 mercury efi with no advance timing module 25 btdc at wide open throttle ok now what should my timeing be for the timing at idle i hooked up my timing lite on it this mourning while it was idleing was idleing bout the same 23-25 btdc is this correct or do i need to change it and also how do set my throttle postion sensor with out the mercury wiring harness that connects to the plug for the multimeter...... so there for which of the 2 wires would i hookup my multimeter up two its a 3 wire plug
- 26Replies
- 14153 Views
- Last post by Rut311969
Apr 26, 2011 6:57 am
- 3108 Views
Aug 26, 2010 3:52 pm
- 16Replies
- 8223 Views
Aug 29, 2010 9:28 pm
- 3647 Views
Aug 28, 2010 4:59 pm
- 2867 Views
Aug 27, 2010 2:37 pm
