I need some help, I had a used CMC 6' manual jackplate installed on my 85 Vulture, I am not having any luck loosening the side bolts.
I am not sure of the age, but according to the manual after doing that I should be able to adjust.
Any help appreciated.
Eric
CMC Manual jackplate / adjustments
Re: CMC Manual jackplate / adjustments
If the side plates are loose it should be free to move. I guess if it didn't move on it's own I would try and help it by aether lifting on the powerhead with a lifting ring or removing the gearcase and jacking LIGHTLY on the mid section. It shouldn't take much, if it doesn't move post some pics.
I was able to get my jack plate moving, prior owner had it way to tight, just took a breaker bar.
Thanks
Thanks
- Jack plate.jpg (868.98 KiB) Viewed 5094 times
shoot lets see some pics of the boat lol... prettty blue.. what height you running the center of prop above or below drain hole iam running center of my drain hole with center of prop runs good there getting bout 15-18 water pressure pretty chinny though lol wot and steer
I have not had it in water, we used straight edge on bottom of boat to come up with starting point for prop.
Prior owner had the boat running 68.5 with no jack plate, I hope to get lower 70's. It has 200 mercury.
I do have pictures of it in my gallery.
Eric
I hope to take it out next weekend.
Eric
Heck, Im in good shape then I hope if your into the 70's with a 200. Maybe 80's or 90's for me then.
- 3741 Views
Aug 18, 2012 8:16 am
- 3471 Views
- Last post by five1five0rws
Aug 18, 2012 11:01 pm
- 7116 Views
Aug 20, 2012 3:52 am
- 3383 Views
Aug 19, 2012 1:03 am
- 15Replies
- 11467 Views
Sep 06, 2012 10:17 am
