I have 3 Hydrostream Hustler Vpads.......My first Hustler recieved a 105hp Chrysler with racing gearfoot no stacks ....That Hustler( not shown here) reached 70mph at 6000 rpm and handled so well, I decided to dig out my other Factory Chrysler racers from my collection and put them on the 2 remaining Hydrostream Hustlers
The pictures below are of my remaining 2 Hydrostream Hustlers 11.6 ft boats........I removed the Johnson 75 Stinger outboards and placed a 135hp Stacker Racer on the Green Boat and then added a 150hp Chrysler Stacker Racer to the Red Boat
Chrysler made 2 Factory Race engines in the 70's ......The 135hp Stacker Racer and the 150hp Stacker Racer......
These motors have all been test run and the Boats all handle well.........Motors are 225 lbs and spin 6000 rpm......These are direct drive gear cases that are 7% overdrive from the factory........I am running 16pitch-- 2 blade Chrysler Racing props..........I upgraded the Motorola ignitions and the dual pumps in each outboard....timing is set at 32..........Gas used is 50/50 Jet Blue mixed with premium with 50 to 1 oil mix
The 150 has 190 lbs compression from the factory
The 135 has 180 lbs compression from the factory
Neither motor came from the factory with tilt and trim
According to Howard Pipkorn, less than 10 Hydrostream Vpads were built between 1984 thru 90....all pre 84 Hustlers are tunnel boats
Factory racing Chrysler Stacker outboards are very rare ....Stack filler blocks and stacks are water cooled
Factory cowls with exhaust cut outs have been removed
Motor height /Gearcase point is 1 inch below the hull
Prop number P411
Chrysler also made the 105 and 120 in racing form.......Stacks did not come with those outboards
Hope you enjoy the photos
I have 4 Johnson 75 Stingers with the Short shafts and nitro cases to sell ... Please contact me at Bradob1@aol.com
please contact me if you are looking for one and I will provide pics and prices
Brad K Rhinelander Wi and Canton Ga.
Hydrostream Hustlers pics with Chrysler Stacker racers !!!!!
- 000_2135.jpg (458.24 KiB) Viewed 6329 times
- 000_2133.jpg (466.34 KiB) Viewed 6329 times
- 000_2132.jpg (497.2 KiB) Viewed 6329 times
- 000_2128.jpg (449.88 KiB) Viewed 6329 times
- 000_2126.jpg (588.22 KiB) Viewed 6329 times
- 000_2124.jpg (524.51 KiB) Viewed 6329 times
Re: Hydrostream Hustlers pics with Chrysler Stacker racers !
Beautiful collection!!!
[ Post made via BlackBerry ]
Awesome! I didn't know Chrysler outboard could make anything that nice!
- 4447 Views
- Last post by Sonik
Oct 01, 2010 10:02 am
- 9547 Views
- Last post by hydrohellion
Sep 05, 2010 2:27 am
- 3052 Views
Aug 25, 2010 8:03 am
- 4170 Views
- Last post by wolfie
Aug 27, 2010 6:22 pm
- 3167 Views
Aug 25, 2010 7:57 pm
