Starting in 1981 omc uses two letters in the model # to identify the model year. They used the word introduces to code the year. So starting with I being 1 or
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
A model #e175 tlco using co would be 85
If you can't find the ser # tag look at the "frost" plugs it is also stamped there witch is also good if the powerhead isn't original.
I just thought this would be handy after this brp uses a year on the ser# tag
omc model year identification
- Location: Oriental , North Carolina / near New bern , nc
Re: omc model year identification
you mite like this one , Monty racing out of Florida confirmed and gave a full rebuild price and mentioned that on pump gas , dyno numbers with mild port matching , i would see around 460 hp and had already built many ! Was said ,$ 7,500 for full job . [album][/album]
That would be way cool, I was thinking of using him for a omc I had but went with mercs instead.
77 viper any info on 88 blue valero would be appreciated like how many rpm it is set up for if you could get any info from guy in your boat club . It would be greatly appreciated . And by the way have you guys ever used cabasil with your glass resin it is a fill you use it to stiifin up resin for horizonal and vert work make thing alot nicer espcly when doing transom work . You can get it at sherwin williams its 100$ a bag but worth it bag well last rest of your life inless you do alot of glass work
Rut I sent you a PM.
- 18760 Views
- Last post by Vegas XT
Jun 27, 2009 10:02 am
- 23395 Views
Jul 09, 2009 8:09 pm
- 22124 Views
- Last post by ccrick
Jul 10, 2009 11:00 pm
- 20178 Views
- Last post by iqraceworks
Jul 17, 2009 12:33 pm
- 21681 Views
Jul 23, 2009 4:40 pm
