another stringer question
should i b considering adding extra stringers for strength when useing a 235hp on a vector i m pretty hard on my toys ie jump n waves transom stands n hopefully 90 plus......thanks for your help n all the great info here
Re: another stringer question
no, but put some "triangles" in. these are simple knee-braces that are made of plywood, glassed on each side and attached below the splashwell, to the splashwell, floor and inside skin of the transom. attach with epoxy and a nice fillet with a couple layers of 1708 on each side. plenty strong.
because it does displace stresses (tensile and compression primarily) over a larger area, which is always good, but, to be honest, the transom is standard procedure, engineered to handle the stresses, and the braces are an adequate upgrade to displace stress. you could do added stringers, too, but in my view, you don't need to do it, unless you enjoy getting scratchy with fibers. know what i mean?
makes alot of sense n atleast thats one thing i dont hav to do to mine.......thank you
i have 6 stringer in my comp hull 18ft vking 2 in the gunnels 4 going to the transome that tie in to it in the pic the gas tank is inbetween 2 of them and 4 goes to the front seat and alittle past it on the sides plenty stronger just blew my merc up so gonna go bigger now
your v king looks killer inside!! we gonna have to find something for you to plug into that thing laying in the port side floor265mercman wrote:i have 6 stringer in my comp hull 18ft vking 2 in the gunnels 4 going to the transome that tie in to it in the pic the gas tank is inbetween 2 of them and 4 goes to the front seat and alittle past it on the sides plenty stronger just blew my merc up so gonna go bigger now
- 5196 Views
- Last post by tommy
Sep 02, 2009 4:48 pm
- 5109 Views
- Last post by ccrick
Oct 28, 2009 12:44 pm
- 11300 Views
- Last post by HustlerV
Jan 01, 2010 2:10 am
- 10597 Views
- Last post by JUPITER VALERO
Sep 21, 2011 11:28 am
- 4275 Views
Aug 31, 2009 10:01 pm
