RubRail
RubRail
Where is a good place to buy some new rub rail for my Vulture? I was looking at this but you cant buy from there site.
Link - http://tacomarine.com/item--1-3-8-x-1-1-2-Flexible-Rub-Rail--V11-0232.html
Any other ideas would be great.
Re: RubRail
Hey man check out this place....I got a crap load of paperwork with my Boat ...I dug threw it and found out that the Previous owner Bought his Rubrail from West Marine....Its been a while but I see they have lots of stuff...Hope this helps ya out http://www.westmarine.com/webapp/wcs/stores/servlet/HomePageView?storeId=10001&langId=-1&catalogId=10001
Re: RubRail
I got mine from Wefco.
http://www.wefcorubber.com/extrusions_marine_rub_rails.asp
The profile is 0137G, it's on the pdf on their site. Works great on the flange type hull/deck joint.
'75 Viper '76 Black Max 175
Re: RubRail
I was looking at that stuff as well. How did you you secure it? Silicone or some type of adhesive?oldskier wrote:I got mine from Wefco.
Re: RubRail
I used 3/8 inch long stainless screws and washers run in from the bottom....I broke off a tiny drill bit so only about 1/4 in. of bit was stickin out of the chuck on the drill. Didn't want to drill through the deck!
- Location: Oriental , North Carolina / near New bern , nc
Re: RubRail
let me know if you still need , cause i got stuck with having to buy a roll of the black and didn't want to piece it .... they will tell you that you can either buy 20 ft pieces , or a 250 ' roll .It is the flexable black vinyl with the stainless continues hook barbs .
Re: RubRail
You wouldn't happen to have a picture would you? I need some rubpail for my vulture.
Re: RubRail
Will this stuff fit over the existing rub rail or do you have to use the insert??
Rick.
Rick.
- 31673 Views
- Last post by slowjoe
Mar 30, 2021 7:36 pm
- 59217 Views
- Last post by harrells1
May 22, 2022 8:52 am
- 24545 Views
Jun 23, 2021 6:49 pm
- 22826 Views
Apr 15, 2021 11:07 am
- 35767 Views
May 07, 2021 5:19 pm
