splashwell corner CRACKED again!
Re: splashwell corner CRACKED again!
That's one thick transom Ron! What's the power source gunna be? Looking forward to see more progress
15" 280 on 8" jack.
Getting fiberglass into the corner joint as far as possible will reduce any chance of cracking at the seam.
I wish the factory would have put some woven roving in with the mat when the splash well was laid up. The corners are the weak link.
I just finished making brackets to mount the bow eye and motor mount holes to a 20' gantry crane. This will serve as a rotisserie. David needs this to work on his splashwell. With the boat up side down and the floor at 6', you can stand under the boat and work on the underside of the splash well.
WHAAAAATTTT!! LOL. I have a couple things cookin. We will see what transpires.
Dave
Dave
Decided to re-do it again. gonna loose the ski locker and move the tank to the floor, loose the splash well and another very cool mod that I will keep you in suspense on if I can find a glass guy that I can trust to do it properly. I still think that the transom is solid I tested a small area a couple days ago and there is no rot that I can find, the jackplate has not made any impressions on the outside, if the knees would have been installed in the first fix as I asked, this would no even be a question at this point. I had it out for a decent run the other night and the crack is not getting any larger, But I want this thing 100% so if I am loosing the well I will do the transom as well. I have a corvette glass guy from way back who has offer to help out, but currently I have 15 motors to re-build and 6 merc complete resto's booked for this winter so re-building this boat is gonna be tight to fit in. I have been trying to fix an overheating 200 for a while and finally got it licked I think, this is a little shot with my 30p DR4 performance prop nowhere near wot, that prop sure like to lift the nose. it's been a while getting used to looking down the nose of this thing you always want more trim- LOL.
I finally got the new Todd front Buckets seats Ron and I have been discussing I got the pedestal and the slides, I am removing the boxes and installing the front seats tomorrow morning will post some pics of them. The look wider but when held up close to the original ones in the boat they are that much more. I went with 6" bell fixed posts which should lower the seat quite a bit in the boat.
- virage30pdr4test.jpg (199.55 KiB) Viewed 3702 times
For perspective, This is Aarons Virage with the seats mounted on the floor. (Aaron and I) This was his maiden run. I got to drive it shortly after. What a rocket!!!
Aaron and ?? Baker at the Frost your nuts run last Oct.
That is slick for sure, aaron did a fab job on that boat. You know I was looking at the new tank designs on the Victory motorcycle tanks and they have one that is flat black with a white semi circle in the middle and then red pin-striping between the white and black, it looked really slick and I thought about this boat right away. It does look good with the lower seats I cannot wait to install them tomorrow my posts are 6" but the seat will sit down on the pole by 3" or so.
have you checked with fibrenew in Gatineau ?
Go fast with class
not to revive an old thread but just picked her up today, all the cracks in the well had allowed water to seep into the transom. It was solid except for the outer 2" on both sides, well she is all fixed now, tank is in the floor knees are in, transom is new and ready to re-rig. finally it only took 4 years - LOL. deck repainted and you can see your face in it, hats off to ronny haylock for a job well done, here is a couple pics of the rigging job I am doing right now on a 81 vector this thing is brand new - sorry should have posted the vector pics first. Oh Well I am *** backwards anyhow.
- IMG_8325.JPG (82.95 KiB) Viewed 3514 times
- IMG_8317.JPG (78.96 KiB) Viewed 3514 times
- IMG_8339.JPG (55.49 KiB) Viewed 3514 times
- IMG_8342.JPG (29.05 KiB) Viewed 3514 times
- IMG_8341.JPG (38.33 KiB) Viewed 3514 times
- IMG_8336.JPG (39.14 KiB) Viewed 3514 times
You're gonna get sick of hearing me say it Dave, I love this boat, can't wait to see it! Looks fantastic!
- 3533 Views
- Last post by transomstand
Jul 11, 2012 11:17 am
- 2973 Views
Jul 11, 2012 11:57 pm
- 6842 Views
- Last post by jacklake2003
Jul 17, 2012 9:32 am
- 10886 Views
Jul 16, 2012 11:04 am
- 3149 Views
Jul 14, 2012 7:04 am
