Viper rebuild
- Been thanked: 12 times
Re: Viper rebuild
Got the hull on the rolling cradle. Had to adjust the bunks a bit and got it to sit well. When it comes time to flip it over, I'll just readjust the bunks to fit accordingly. The hull is at a good working height and the cradle is heavy enough that I'll be able to rig it with the engine prior to going back on the trailer. Starting to get pumped!!
- DSCF4870 (Copy).JPG (82.35 KiB) Viewed 7574 times
- DSCF4875 (Copy).JPG (75.91 KiB) Viewed 7574 times
- DSCF4876 (Copy).JPG (85.01 KiB) Viewed 7574 times
Re: Viper rebuild
that thing looks sick man......wish i could start with a hull that nice lmao!!!
Re: Viper rebuild
That is a killer shop you got there, the boat is looking badazz and ready to see it in the finished form.
Re: Viper rebuild
Very sorry for not updating the past 2 years, going to try to bring this thread up to date. Time to start on the business end of the Viper!
Re: Viper rebuild
Adjusted the bunks and came up with a great, stable working height. There's a lot of work to do before it's straight and crisp. It's a first generation design Viper bottom
- DSCF4906 (Copy).JPG (80.26 KiB) Viewed 7071 times
- DSCF4903 (Copy).JPG (87.42 KiB) Viewed 7071 times
- DSCF4900 (Copy).JPG (102.61 KiB) Viewed 7071 times
Re: Viper rebuild
Only a few low areas to build up. Once the first grind gets finished, the blueprinting begins.....
Re: Viper rebuild
Completely rebuilt the trailer while the hull was off. Came out pretty decent for a 1979 trailer. The bunks were adjusted when the hull was ready to go back on.
- IMG_0045 (Copy).JPG (163.83 KiB) Viewed 7071 times
Re: Viper rebuild
The bottom is now finished. I decided to fill in the pad and straightened/sharpened all the strakes and trailing edges. The boat won't be a cruiser so a performance bottom finish was done.
- DSCF4999 (Copy).JPG (55.05 KiB) Viewed 7071 times
- DSCF4998 (Copy).JPG (73.71 KiB) Viewed 7071 times
- DSCF4996 (Copy).JPG (42.13 KiB) Viewed 7071 times
- DSCF4991 (Copy).JPG (44.61 KiB) Viewed 7071 times
Re: Viper rebuild
Now to set the trailer bunks up.
- DSCF5011[1] (Copy).jpg (73.4 KiB) Viewed 7070 times
- DSCF5009[1] (Copy).jpg (69.34 KiB) Viewed 7070 times
- DSCF5007[1] (Copy).jpg (57.16 KiB) Viewed 7070 times
- DSCF5005[1] (Copy).jpg (57.69 KiB) Viewed 7070 times
- 5602 Views
- Last post by Sonik
Oct 26, 2011 9:13 pm
- 6578 Views
Oct 27, 2011 4:06 pm
- 5383 Views
- Last post by Andyhydro
Oct 29, 2011 8:52 am
- 13273 Views
- Last post by coupe
Nov 01, 2011 10:45 pm
- 9947 Views
- Last post by blowitup
Oct 29, 2011 8:54 am
