1978 Vandal full restoration
- Been thanked: 14 times
Re: 1978 Vandal full restoration
Blue printing and straightening out the bottom. And a million blisters to fill. I don’t have many pictures, but this took a ton of time filling and sanding. I added cloth anywhere it was over .050 deep. For the blisters I mixed up some milled fibers and cabosil.
- EF1B62C5-2F9E-48F9-9024-B00DE2FA2BFD.jpeg (283.39 KiB) Viewed 24980 times
Painted it with Endura paint. Roll and tipped. 2 coats. Hope it holds up. People report its excellent boat paint, but it’s still paint. Not gell. I didn’t want to invest in the equipment and education around spraying gell coat.
- 410290F2-CDAA-40E0-94AC-75B837A8E0EE.jpeg (2.17 MiB) Viewed 24978 times
- 6C204F54-6E12-4C42-ACDD-D6867B878372.jpeg (2.7 MiB) Viewed 24978 times
Looking good! Glad to see you're still at it.
Thanks for the props hippie! I’m determined to get it wet in 2021. I got a bobs convertible jackplate that I’ll run in 2.5” mode, a hot foot, dual cable rotary style steering that I don’t know if it is a great move, and a 90’s Johnson 115 crossflow v4 to rig up.
I wrapped the deck in white vinyl. I used to wrap stuff for a living, but got out of it 8 year ago. It was 100% free cost for me. If it holds up ok I may spring for some metal flake vinyl which would be roughly $400 in materials. They have all the great colours including a white metal flake that is really cool.
I also weighed the boat as it is now. It comes in at 340lbs. Not to bad from what I gather. I didn’t skimp on resin or use lite weight materials. The only differences from original I know of are epoxy, vacuum bagged core, transom knees. I did put a layer of 4oz weave on both sides of the floor, and put a layer of glass on any wood anywhere. That’s definitely more then factory efforts from what I seen tearing it apart.
- BB78E6DA-4C35-4E98-869D-C056CA7ECF78.jpeg (284.07 KiB) Viewed 24947 times
- 7FCA8ECF-20AA-43DB-967F-4CC4C23188AD.jpeg (383.76 KiB) Viewed 24947 times
- 889C3D23-AEAE-4D14-AD2E-4B17225D84A9.jpeg (312.01 KiB) Viewed 24947 times
- 1888795C-BA79-4BC0-A54B-F8C42D97286F.jpeg (335.01 KiB) Viewed 24947 times
- C9A20A96-00B8-4D14-8189-E9A7018E5CAD.jpeg (352.94 KiB) Viewed 24947 times
- 53B87250-B9F3-48A4-90C4-998759C4C3FE.jpeg (309.34 KiB) Viewed 24947 times
- 3CA847A6-017E-496B-9D9B-4F620685AEE4.jpeg (268.97 KiB) Viewed 24947 times
- 456CDECE-1D15-4183-87D1-5B0840413723.jpeg (366.59 KiB) Viewed 24947 times
That's crazy that that is a wrap. I would love to do a white flake on my boat. I have never seen it before. Looking great though!
I rigged up the Vandal!!!! Bare minimum. It’s setup about 2.5 inches below the pad with a 13.75 x 21 aluminum prop. Trim on the wheel, and a hot foot.
Motor runs flawless. It’s super fun to drive. The acceleration to about 50 mph is addictive.
I was jumping it, and giving it a beating to see if the work held up. So far after many inspections I only tore up the control box mount of the hull a tiny corner.
For next time out I’m going to plug the top water intake hole on the lower, raise it an inch, and maybe try the 14 x 24 small ear chopper. I need solid mounts real bad though.
Looks great!!!!!
I bought a 78 vandal, questions. is a 11 by 17 ft garage big enough, and what was the material cost of the restoration.
It will fit corner to corner.
I used Rayplex epoxy, balsa, marine plywood, sundries and various 12, 6, 4 oz cloths and weaves. I think the total was about 2500 for all the fibreglass stuff. Paint, and wrap, etc not included in the 2500
I bought my glass weaves, cloth, and balsa from Noah’s marine. The fillers, resins, and Sundries from Rayplex.
- 49184 Views
Mar 01, 2021 6:53 pm
- 21989 Views
Mar 02, 2021 6:08 pm
- 21833 Views
Mar 06, 2021 9:22 pm
- 31732 Views
- Last post by slowjoe
Mar 30, 2021 7:36 pm
- 59297 Views
- Last post by harrells1
May 22, 2022 8:52 am
