You are doing a great job and making good progress Ron. Thanks for sharing the pictures. Brings back the memories of when i was doing mine!
Thanks to you Glenn for chatting on messenger and sharing pictures of your HST build.
One thing we were discussing that I rectified was that silly deck to hull overlap going across the transom.
That extra fiberglass in the overlap created a large lip for a jack plate to sit on and not against the transom.
Glenn ( Big boy) shaped some plywood to create a flat surface and Ron Flood has an aluminum plate to bring the upper transom out to the overlap level.
The lower bolt holes go thru the overlap so there’s still an issue below that area to address.
The easiest solution was to remove this strip and glass the two outer skins together.
This now allows the inside to be perfectly flush.
- 88E1F550-A516-45D1-A787-856F1C9FA52C.jpeg (92.41 KiB) Viewed 15902 times
- 92686B0B-EB48-4053-B1FC-C84E7EF7E1EB.jpeg (116.78 KiB) Viewed 15902 times
- 47254C1B-3B0C-47A8-8104-F9B1316A3200.jpeg (382.49 KiB) Viewed 15902 times
- C720783F-3491-44C5-AE33-75A86A8F0D2C.jpeg (314.09 KiB) Viewed 15902 times
I’m going to try to use a corrugated plastic campaign sign as a core on the wind screen.
I’ll report if it will hold up to the resin.
- 432E9F7E-465A-4C48-B77F-CCEB16E42F90.jpeg (101.35 KiB) Viewed 15900 times
- 9763FA3B-981B-457A-AA20-B3DF0757A94C.jpeg (106.59 KiB) Viewed 15900 times
- 8B451D09-95C8-4B95-B905-669C4FE06A78.jpeg (106.62 KiB) Viewed 15900 times
It’s coming along nicely hurry and get that thing done so I can drag mine over lol
Little catch up after a week of being sick.
Transom and knee braces installed , transom seam V’d out and glassed back ( now it’s straight top to bottom!!!!!) boat flipped , molds pulled, deck to hull overlap filled with 3M-5200.put a light in my caulking gun to see in the gap. (Both surfaces were roughed up before the deck went back on.)
- D4B22D11-14F7-4F4D-8B6B-3F46F093F249.jpeg (420.66 KiB) Viewed 15824 times
- CE419A53-E7DA-415A-8A97-32B2A92BF8A9.jpeg (321.13 KiB) Viewed 15824 times
- 10DE70B1-AE8F-432F-BF49-49C88AAF228A.jpeg (326.32 KiB) Viewed 15824 times
- D4E3A137-2C9D-4DD8-B592-424E67F79E25.jpeg (344.39 KiB) Viewed 15824 times
- F9C76C32-3412-4B11-A05F-C3E17F949B7C.jpeg (329.66 KiB) Viewed 15824 times
- 0487060A-459E-403D-B1AB-BDD92171F8FD.jpeg (314.49 KiB) Viewed 15824 times
- FF5A41EC-4C2D-4E89-9675-8690BB72DAA4.jpeg (341.74 KiB) Viewed 15824 times
- DAD01154-413C-47BD-BF3D-4919C475D1CD.jpeg (326.64 KiB) Viewed 15824 times
- 42888EE6-45C5-4F02-8B71-9E929136A360.jpeg (382.6 KiB) Viewed 15824 times
- 0B4575BE-6D45-45F2-BC2D-2B0BD4462493.jpeg (349.35 KiB) Viewed 15824 times
- 916BF1E0-F842-48E4-AE0D-A799F3DA6087.jpeg (309.28 KiB) Viewed 15824 times
- C531C49D-A92E-49D4-B9DB-9983B830D11A.jpeg (331.3 KiB) Viewed 15824 times
- B02426FD-5FC3-4FFC-99B0-C8A26A4EF8D6.jpeg (374.05 KiB) Viewed 15824 times
Spent 4 hours grinding the bottom. Mainly removing gelcoat. There was some delaminating in the corners where the center sponson meets the tunnel top. Both sides.
About 10’ each side in the 1/2” radius. Great fun carefully sweeping 24 grit to remove the bad.
Laid in chop glass strips.
It appears the boat was removed from the embankment with a boom truck!!
The area around the bow eye was fractured pretty good . Inside the hull all looked good. Had to remove quite a bit of material before repairing.
- D30614BC-32F9-44C8-95CC-EC9A5B515326.jpeg (389.99 KiB) Viewed 15802 times
- A343F52F-E528-4AB6-9101-EF7BFD90A83B.jpeg (366.84 KiB) Viewed 15802 times
- 99F493AF-3D46-47D5-8EF5-BAE936993944.jpeg (296.13 KiB) Viewed 15802 times
The things we do for fun. Looking awesome!
Can’t wait to see it this weekend ! Please stock your fridge before I get there lol
Ohhh the fun!!
Thickened gelcoat as fairing putty.
- D10850F3-8879-4CC9-AC0E-9B4D3E068AFF.jpeg (405.12 KiB) Viewed 15789 times
- 226009 Views
- 163055 Views
- 197538 Views
- 167196 Views
- 106184 Views
- Last post by msethsmile+
Dec 12, 2018 10:24 am
