Hydrostream Vandal Restoration (Maple Leaf edition)
Heres the link to S&F Doing a complete restoration, Hopefully should turn out nice for the summer Wish me luck! Guys
http://forums.screamandfly.com/forums/showthread.php?t=173123
1982 Hydrostream Vandal
Currently restoring...
Re: Hydrostream Vandal Restoration (Maple Leaf edition)
Here's some pics! Poor old stream!
All de rigged and ready to start cutting and grinding! I like it better without the windshield, Don't you think so too?
Took the plate off to discover more holes, Wonderful!
Got a center bunk for the pad to sit on
Cut splashwell and inner transom skin, A little bit of rot around the old inline bolt holes, So Its all coming out!
Cut into the core and guess what! BLACK MUSH! Bright side is it comes out pretty easy!
Stringers wet and rotten too!
A lil bit of repair on both wings, I assume it was in some sort of accident. Bottom was painted also...
Core and stringers out and inside cleaned out! Also cut out the flotation foam I thought was dry was Soaked and staturated
(If you can see there is a hole where I accidently poked my chisil threw when getting the core out, WHOOPS)
Transom out and cleaned
I have a bit more grinding to do around the transom and what not but im Pretty much done grinding!
Looking good. Hope mine comes apart easy when I redo it. I am thinking I am gonna pull the deck when I do mine to fix a few things. I will figure all that out come winter time though.
Hippie459MN wrote:Looking good. Hope mine comes apart easy when I redo it. I am thinking I am gonna pull the deck when I do mine to fix a few things. I will figure all that out come winter time though.
I wouldn't recommend it, Without the core stringers and transom the boat is terribly thin and flexible, Even leaning on the side of mine causes it to flex!
- 3343 Views
Jul 14, 2010 10:43 pm
- 3239 Views
- Last post by transomstand
Jul 20, 2010 4:03 pm
- 5282 Views
- Last post by jacklake2003
Jul 19, 2010 9:33 am
- 2965 Views
Jul 15, 2010 4:41 pm
- 26Replies
- 13704 Views
- Last post by Alexjoz
Sep 15, 2010 5:15 pm
