84 V-king set up
84 V-king set up
Just bought a 84 V-king last week. It currently has a 86 evinrude 140 V4. The motor also has the dolph fins on it. What would be a recommended prop for wakeboarding and good top speed?
Re: 84 V-king set up
It Depends on you current set up? Jackplate, low water pickup and whats on it for a prop now? If your not surfacing the prop with a 140 and need a holeshot I'd say 20 to 21 pitch prop just as long as your not pulling up godzilla. Let us know the set up and welcome!
Rick.
Rick.
ccrick,
No jackplate or low water pick up. The motor has a 13 x 19 prop which now has a bit of damage from shallow water driving. Since I am new, I do not know what you mean by surfacing the prop.
Some have recommended a 25 pitch but they do not know much about the v-king. I am thinking about a manual jackplate. Do I need a low water pick up when running a jack plate? I would like a prop recommendation without a jack plate and with one. Thanks john
Hi, you can jack the engine some but without a lwp you can't let you water pickups on either side of the gear case get above the water. I don't have a jack on mine yet but my engine is mounted high. What I mean by surfacing is the prop is partialy above the water. The higher the engine is out of the water the faster it will be but your holeshot won't be as good when pulling tubes or skiers. You want the engine in deep for that. As far as a prop, I run a 23" pitch lazer 2 and last year my engine was spinning 6500 to 6800 rpms. For my motor is the upper limits. OMC's run lower max rpms. When my hull is done this year I'm sure I'll need more prop because the boat will be much lighter. 19 pitch seems kinda low. I guess the thing to do is see what you rpm's are at wot. Dont spend any big $$$ on a prop till you get a jack. Manual jacks are ok but I know when I get one it's going to be hydrolic. Adjustment on the fly. Ultimatly for flat out speed, you'll want the prop shaft an inch or less below the pad. If you look under the back of the boat, there's a flat section at the keel thats resessed forward of the transom.Thats the pad if you don't already know. Then a 26 chopper or srx prop. Still, you need to see where your rpm's are at now. Feel free to ask if you have more ???.
Rick.
Rick.
Thanks again... Do you happen to know what the max RPMs would be for my evinrude?? I think what I will do for now is have to props. Onefor pulling and one for speed. What do you think would be a good pitch for speed not knowing my current rpms??
Oh, by the way my tach is not working... Could you provide me with the stock wiring set up so I can make sure it is wired right before I buy a new tach.
Ya gotta start with current rpm's The OMC'c and Mercs are different beasts. As far as the wiring for the tach, maybe someone can chime in that knows OMC's. Once you know the max rpm rating of the motor and rpm's at wot, should be able to make a judgement call on a prop.
Rick.
Rick.
As far as your tach there should be a purple wire to power a black to ground and a gray to the signal post. It could be your voltage regulator is bad the tach signal comes out of that. It's on the tpo of the block between the cyl.
Viper, any idea what max rpm would be on that motor???77viper wrote:As far as your tach there should be a purple wire to power a black to ground and a gray to the signal post. It could be your voltage regulator is bad the tach signal comes out of that. It's on the tpo of the block between the cyl.
There is a tag on my motor showing the max rpm to be 5500 and max HP at 5000. Viper, thanks for the info. The gray wire comes off the control box below the key at the same spot the temp sending wire enters.. Does that sound right?
v-king that sounds right 5000-5500 or you could just keep cranking on it till the limiters kick in.
- 4126 Views
- Last post by havingfun2
Sep 23, 2009 6:56 pm
- 7939 Views
- Last post by king gill
Sep 22, 2009 11:02 pm
- 3556 Views
- Last post by billyho
Sep 23, 2009 2:33 am
- 3450 Views
Sep 23, 2009 3:08 am
- 27Replies
- 12585 Views
- Last post by jlw7
Jul 12, 2010 12:44 pm
